Old 21-03-2006, 10:04 PM   #1
capa xr8
Default underdrive pulleys
has anyone tried the underdrive pulleys are they worth the money do they give you more power
capa xr8 is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 10:40 PM   #2
Redrum
Force Fed Fords
Redrum's Avatar
The V8 technical section on this forum did have a thread relating to under drives but last time I looked, I couldn't find it. Best to speak to sponsors who supply them.
2021 Focus ST-3 Mountune Enhanced
Redrum is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 12:07 AM   #3
superpursuit83
KITTY Crew Member
superpursuit83's Avatar
Have a look at this thread Underdrives discussion
Underdrives basicaly let more power go to wheels, Less weight to spin etc. Thats how I understand it anyway.
John
FOR SALE
BAII Super Pursuit 0083
Awsome power by XTREME FORD TUNING 500rwkw New ALLOY Block
Awesome exhaust by THE EXHAUST CENTRE MIDLAND
Awesome Kenne Bell Supercharger setup by AGRO! and Bluepower Racing Developments
Now with full DOT approval and Permitted for road use
superpursuit83 is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 12:09 AM   #4
Redrum
Force Fed Fords
Redrum's Avatar
Thanks SuperPursuit, thats the thread I was thinking of!!
Old 22-03-2006, 12:23 AM   #5
chief
FTF Club Moderator
chief's Avatar
An underdrive pulley also throws out the balance on your engine. Ford will not cover warrenty if you have one of these fitted.
Albert Einstein:
Fords in the Park 2010
Old 22-03-2006, 07:37 PM   #6
ratter
ratter's Avatar
Balance is not the problem, ford are claiming harmonics are a problem, byt no solid proof has been presented.
Pit Lane Performance
Old 22-03-2006, 07:47 PM   #7
BA_BOSS
BA_BOSS's Avatar
John
UDP’s change the pully ratios by x%. By putting a smaller pully on the crank and larger pulleys on the water pump and alternator , the crank requires less effort to spin them therefore the engine will spin up quicker and a bit more snot to the driving wheels.
Effect is much like what the gear box does, 1st gear will accelerate the car quicker than 2nd gear and so on.
BA_BOSS is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 08:56 PM   #8
Rollin
Rollin's Avatar
isnt the pulley and the harmonic balancer two pieces on the windsor? or do you have BA?
if you leave the balancer alone and just replace the pulley, i see no reason for there to be problems with harmonics, and even if you replace the whole thing, it may not make that much of a difference anyway - lots of people (esp with chevs i think) put steel balancers on their V8s and dont seem to have any dramas, though they are making a shedload of HP.
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 09:09 PM   #9
pertuan
Focus on my Focus
How much more power to the wheels would you gain from replacing the pulley? Is it a notable difference? I personally didnt think it would make THAT much of a difference.
Now: 2006 Ford Focus LX Manual in Satin White
Wife: 2013 Kuga Titanium in Frozen White
Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way.
Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05)
American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon
pertuan is offline   Reply With Quote Multi-Quote with this Post
Old 22-03-2006, 09:25 PM   #10
chief
FTF Club Moderator
chief's Avatar
Originally Posted by ratter
Balance is not the problem, ford are claiming harmonics are a problem, but no solid proof has been presented.
Sorry then I will clarify an underdrive pulley also throws out the harmonics on your engine. Ford will not cover warrenty if you have one of these fitted.
Albert Einstein:
Old 22-03-2006, 09:34 PM   #11
chief
FTF Club Moderator
chief's Avatar
Sorry I will rephrase: An underdrive pulley also throws out the harmonics on your engine. Ford will not cover warrenty if you have one of these fitted.
Albert Einstein:
Old 22-03-2006, 09:50 PM   #12
X ORSMXR
missing the panther
X ORSMXR's Avatar
Mate can only go by experience if choosing a under drive l would go with powerbond under drive as have not heard of any dramas with them but heard and experienced plenty with the BPT under drives...
X ORSMXR is offline   Reply With Quote Multi-Quote with this Post
