Old 10-03-2006, 10:16 PM   #1
Mark351
Built Ford Tough
Mark351's Avatar
Default Wheels, Tyres, and why IRS is not better than live axle when upgrading
Not sure if any of you are deeply aware of rules governing aftermarket wheels, but as far as the increase in wheel track in Vic goes, IRS-fitted cars are only allowed an addition 25mm increase. I think the maximum tyres width put on an AU XR was a 245 (on an 18"x8" wheel) so the max you could increase to would be 255 on each size. Those of us with older live axle setups, can legally go to 265mm of each side, as the max increase is 50mm.
With the rules also allowing only a 25mm increase in wheel width, I wonder how rigidly this is scrutinised, and if that is why 8.5" and 9.5" wheels are made available, when presumably those with an 8" with wheel could to to 9", except an inch is technically 25.4mm.
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread
'55 F100, just a roller at the moment, new project
Silver MY12 Volkswagen Amarok
Mark351 is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2006, 10:21 PM   #2
Casper
Contributing Member
Casper's Avatar
bwahahahhaaha.. laws.. bwahahahhahhaha..
Shhhhhhhhh, dont open my bonnet, I'll be stuffed.
Anyhow, good pick up and actually very good info to take note of .
While we are on "laws" though, apparently if we increase power more than 10% of factory fwkw we need an engineers certificate too!!! :
Older, wiser, poorer.
Old 10-03-2006, 10:29 PM   #3
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
only law i have ever hear about tyre width is so long as the tyres dont protrude out the guards ( the rears i mean , the front usually allways do a tad due to the nose of the car being narrower ) . The only thing i can see happening with irs and too wide a rim , is it would prolly cause a bad camber (riding the insides of the tyres more) , nothing a camber kit cant fix .Maybe without addition setup it might be illegal to go wider than stated on the IRS setup , but im sure there is a reason and a fix/mod u can do too to make it legal .
:eclipsee_
Old 10-03-2006, 11:05 PM   #4
T_Terror
The Guy You Love To Hate
I dont believe thats correct about the 245 max width tyre for IRS Aus.
I remember the laws saying somehting like a certain amount of mm over stock width, didnt XRs come with 225 or 235 rubber?
No cop will ever pick you having tyres that are too wide, unless you are in a skyline with a loud BOV and a smartass P plater.
T_Terror is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2006, 11:19 PM   #5
XR6-VCT-2000
Fantastic Plastic
If you open the front drivers door on the au xr (on most cars actually ) there is a sticker on the door stating maximum size tyres , it states 245's are max , allthough i think from how it looks on the chart/sticker that they are refering to is that is the largest width tyre you can put on 'THAT WIDTH RIM' that came 'WITH' the car ! ,
:eclipsee_
Old 10-03-2006, 11:33 PM   #6
tufLTD
tufLTD
tufLTD's Avatar
Spot on. Wheel track is measured from centre of rim to centre of rim. Tyres won't affect this, only rim width will.
The reason for not allowing wider rims is the extra load it places on wheel bearings, although I don't know why IRS would be different to live axles?
tufLTD is offline   Reply With Quote Multi-Quote with this Post
Old 10-03-2006, 11:39 PM   #7
Mark351
Built Ford Tough
Mark351's Avatar
I don't write the rules!
T Terror, I said 255 would be max, given 245 was the max allowed by the manufacturer.
Also, beware of load rating for tyres. You are not allowed to fit tyres that are lower in load rating than those recommended.
