I strarted using the auto as a manual, like start in 1st, then 2nd, then 3rd and finally drive (which is 4th)
Will this wreck anything in the car? Cheers Simon Last edited by OZFORDAU; 23-02-2006 at 04:35 PM. |
lol, i dont really see the point beside the car reving higher if you dont change to next gear.
its basically 1st gear means it will only use 1 gear, 2nd gear will use both 1st and 2nd gear 3rd gear will use 1st 2nd and 3rd gear whilst driving and d will use all 4.. i change to lower gears when going down a hill when i cbf using breaks much. heavy engine breaking it is. i wonder if this hurts the car? |
SUMP PLUG
I do it all the time to help me slowing and to time the changes when "I" want them to change.
No prbs, although occasionally when I go from 3-4 at speed, the thing gets a little mixed up and the overdrive kicks down for a sec. Back off and it changes up no probs. |
PM me if you want
Its the whole reason why I fitted the BA shifter, so I could do it all the time easily
#5 | |||
And can i change the gears down? Like from drive to 3rd, 2nd and 1st Cheers Simon |
#6 | |||
if coming down hard use the brakes with the down shift to avoid / lessen drive line shunt. i.e apply the brakes as per normal , when revs speed right throw it down. by doing this there should be no shunt at all with practice this applies to both the older and BA style shifts. |
PM me if you want
second hand shifter is about $150 and about $200 for electronics, make a bracket and have a good day, click the link in my sig for further details
![]() yes you can change up and down the gears, JC has put one in is AU thread somewhere too.
#8 | |||
Adapt or perish...
Carless
#9 | |||
edit in theory your manually changing a little above or below where the normal changes would take place if in auto mode dont over stretch the gears before moving up ( unless your having some real fun ) and when shifting down common sense prevails, dont throw them down if your rev range is to high, keep it in sync with the motor. if coming down hard use the brakes with the down shift to avoid / lessen drive line shunt. i.e apply the brakes as per normal , when revs speed right throw it down. by doing this there should be no shunt at all with practice this applies to both the older and BA style shifts. |
Adapt or perish...
Should've made myself clearer...
How does manually shifting an auto box help protect it?
Carless
#11 | |||
#12 | ||
Adapt or perish...
Oh, oh.
So you meant if your manually changing the auto, here's some pointers to help protect the box. ![]()
Carless
#13 | |||
all good :sm_headba |
#14 | |||
they call me Tibbo
#15 | |||
Adapt or perish...
Carless
#16 | ||
![]() Join Date: Jan 2005
I use mine manually. The ESS as fitted to auto T series cars, and the SSS fitted to BAs proves that the practice is valid, IMO. I will be fitting the ESS to my XR8 as soon it is ready to go (a month or so, I guess). The BA shifter into the AU was a huge success - until I melted through the shifter cable with the extractors - I should have used a heat shield, but thought I'd get away without it. Total cost was around $150 for shifter mechanism, $200 for electronics, plus 12 hours to fit!
#17 | ||
so why does my trans stink every time i start playing with the gears? it doesnt smell when i boot it in drive. if it somehow helps it, wouldnt it not smell no matter what? maybe mines a dud :P
#18 | ||
Just slidin'
I use mine all the time. I like holding it in first till about 40 in first in the wet, and then letting her rip. AAnd overtaking on the highway, back to 2nd for a sec before booting it gives a lot better response.
MD Mondeo - For the family
#19 | ||
running from explosions
But booting it throws it back to second anyway?! :S
I don't constantly drive mine like a manual, but I definitely do make use of the lower gears when climing steep hills, or when descending to avoid riding the breaks excessively. It has been said many times by people I know that changing to anything but 1st while going is fine. Apparantly 1st should only be selected if stopped or at a slow crawl. Seems to make sense... And Monty, you are smarter than me ![]()
Daily driver: Pushbike Offroad fun: Mountain bike Long journeys: Ford Ranger dualcab |
#20 | ||
I drive it like a manual when driving under load (towing or heavy ute loads)
Oh ... you can easily fit 12 kegs of beer from Tooheys standing up in the back of the ute as well ... tests the suspension a bit ... sorry .... no photos .. I was not allowed to take a photo with my mobile phone either ... grrrr. But I do use the auto manually when shifting down ... also under load when shifting up ... i just get it to hold each gear longer when having to take it easier ... like yesterday afternoon with the 12 full kegs onboard.
#21 | ||
Back on the road
I almost always select gears manually driving an auto. I don't have to wait for it to kick down when accelerating out of a corner, and I don't have to wonder what it's going to do when driving in the wet.
I wish I had a clutch for first gear though so I could get off the line a bit quicker when I want too :P
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
#22 | |||
#23 | |||
XR8 v Lee. love you Lee
Very interesting...... Just had a shift kit installed and "wow" but i havent tried it manually off the mark , by what i read of the electronic kit it speeds up line pressure but im sure i read it locks the thing up quicker as well ?
1993 EB2 FALCON S XR8 As original from showroom floor with all options Additions - Pacemakers turbo400 3" exhaust Custom cai prototype No 4 Stage 1 shift kit with neck brace Still to come DIVORCE |
#24 | ||||
Back on the road
![]() But I also want a GnD airbox, custom tune...run a 13, and then fit the blower. And i need 4 new tyres, a non-vibrating tailshaft, and a new steering rack. My wallet is just too small at the moment...lol Quote:
#25 | |||
#26 | |||
#27 | ||
FTF Club Moderator
I drive mine as a manual under load, or having the occasional bit of fun. If you want to drive your auto as a manual, I think a tranny cooler would be a good idea. Last time I drove my wagon around as a manual the centre consol became hot. So it is probablly recommended that you fit one.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
