Old 07-02-2006, 03:05 PM   #1
snozzau
Default Idle Problems!!!
Guys,
Had extractors and new exhaust fitted,got the the car home and did the ECU reset as per instructions and now the car cant seem to make up its mind what speed it wants to idle at.
Sounds like someones under the bonnet revving it up to 1200rpm then back to nearly stalling.
Please dont tell me I have to go the local ford dealer and get the idle codes reset.
Any ideas welcome.
Snoz
snozzau is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 01:19 AM   #2
XR6-VCT-2000
Fantastic Plastic
XR6-VCT-2000's Avatar
Hi - seeing no one else is dropping any suggestions maybe try this, all i could maybe suggest/ask is .... did you set the transmission to adaptive shift mode after reseting the ecu then drive it on adaptive shift ( shift mode 3 ) for the first full tank ( roughly 400km ) ?????? , if not - reset the ecu again and try that - also make sure u got good fuel in ya car , not cheap unleaded . Maybe this wil help . gl
Old 08-02-2006, 01:24 AM   #3
XR6-VCT-2000
Fantastic Plastic
OOps , forgot to mention that i was on about if u have an Auto , not manual , also did the guide u read on reseting the ecu describe about running the a/c for a few mins on , then few mins off etc etc ???- if not -> make sure to read up on steps to follow after reseting the ecu , this does include idleing the car for certian amonts of time with the a/c on and off for certian amounts of time in Nuetral and in gear etc etc etc .
Old 08-02-2006, 01:55 AM   #4
OZFORDAU
OZFORDAU's Avatar
Thumbs up Rest ECU
To Reset AU ECU?
Disconnect the battery for approx 40minutes to 1 hour.
Once reconnected do the following:
AUTO Transmission:
- Reset Computer by disconnecting battery (Take off the positive terminal lead)
- When power is re-connected, start car and idle in this sequence?
- 2 minutes idling with the transmission in drive and A/C on.
- 2 minutes idling with the transmission in drive and A/C off.
- 2 minutes idling with the transmission in neutral and A/C on.
- 2 minutes idling with the transmission in neutral and A/C off.
- Drive the car on the road, for at least 5 minutes under variable throttle positions.
MANUAL Transmission:
- Same as above, except put the transmission in gear for (drive).
Often, resetting the ECU can give the car a fresh start, improving performance, economy and smoothness. It is recommended that an ECU reset is done after any modification to allow the computer to relearn the car and the driver
Hope this helps!!!!!!!
OZFORDAU is offline   Reply With Quote Multi-Quote with this Post
Old 08-02-2006, 02:34 AM   #5
snozzau
The car is a manual and I followed the reset procedure word for word.
I'll try it again but go for a longer test drive this time.
Old 09-02-2006, 12:58 AM   #6
JC
JC's Avatar
Disconnect the electronic plug from ISC solenoid (it's attached to the Throttle Body) and see how it idles then. If it's better, then remove the ISC solenoid and clean it using WD40, RP7 or carby cleaner. Replace it, plug it in and see how the car idles then.
Ford Performance Club ACT
