Old 27-01-2006, 03:51 PM   #1
boodek
Ferret
Default Uneconomical AU3
I've just filled up the Futura sedan again, and managed to get only 375km for 58 litres - that's 18mpg or 15.5 l/100km. My wife drives the car and she is very sedate and cautious, and much of her driving is around town (Albury). Any ideas what may be wrong with the car?
boodek is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 03:55 PM   #2
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
If it was an auto, and the 375 km was all stop - start, slow driving then there's probably nothing wrong with the vehicle.
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 04:15 PM   #3
buickman
buickman
buickman's Avatar
I get over the 400kms out of a tank in a VCT AU ghia with stop start.
My average now is about 13.5-13.8L/100Km around town & 8.5-9.5l/100km on H /ways at around the 90/100Kph speed.
Try a air filter change as mine was running in the high 14's/100km with a blocked air filter.
Old 27-01-2006, 04:22 PM   #4
SIKSIX
Its gone V
SIKSIX's Avatar
also try spark plugs and leads, that helps. my brother got about 760 km on one tank (on the trip melb to syd) all freeway driving with four people also running AC on and off. ps before we left for the trip the car just got serviced at ford....
SIKSIX is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 04:44 PM   #5
FTE217
T3/Sprint8
FTE217's Avatar
It seems traffic at the border is worse than Sydney !
Mate I get that out of my XR8 or less if I push it even harder in Sydney traffic !
When was the last tune ? Air and fuel filters changed ?
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 05:03 PM   #6
boodek
Ferret
We've had the car for about 6000km now, it had it's 75,000km service just before we bought it. It was done at the local Ford dealer (who I find particularly useless when servicing our work vehicles) so I imagine filters would have been changed then. I'm thinking of booking it into the local fuel injection specialist for him to go over, I imagine there may be a dud sensor somewhere in the system.
Old 27-01-2006, 05:46 PM   #7
Baboon_AU
Baboon_AU's Avatar
if you have excessive fuel consumption there are a possible number of things you can check out:-
1-check that there is no external leak in the fuel supply system-check all components for signs of leakage
2-check the air cleaner to see if it is blocked, if blocked clean or replace with new element
3-engine may be running too cold due to a faulty thermostat
4-you may have high fuel pressure. test pressure, if high check fuel return line and fuel pressure regulator
5-you could also have an exhuast system blockage-check system for blockage
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 07:42 PM   #8
XR6Stu
It must be consistency Ford strive for in their service department, as my local dealer in Bendigo is also particularly useless. I no longer take my VCT there, as they continually stuff me around, and usually require a follow up visit once i drive the car, and discover whatever the issue is, has not been fixed!
XR6Stu is offline   Reply With Quote Multi-Quote with this Post
Old 27-01-2006, 08:20 PM   #9
Voodoo65
Voodoo65's Avatar
Default Fuel economy
I had a similar problem and reset the EEC, takes about an Hour and a half and its free.
And put bottle of Injector Cleaner in the tank, I've been told about 3 - 6 tank fulls to add one, someone could shed more light on that though....
The proceedure is on the AUfalcon web site go to www.aufalcon.com.au "workshop", then "Correct procedures after battery reconnection (by LG)"
I was getting around 400 - 450 kms out of a 68 Lt tank and after reseting 550 kms.
Can't hurt to try it
BA XR8 2003, Acid Rush, Leather, Premium Sound & Tint.
"There's no substitute for Cubic Inches"
Voodoo65 is offline   Reply With Quote Multi-Quote with this Post
Old 28-01-2006, 02:34 PM   #10
boodek
Ferret
Thanks for your replies. I've tried the resetting of the ECU a couple of times to no avail. All I want is another 100km per tank...
Old 29-01-2006, 07:43 PM   #11
Baboon_AU
Baboon_AU's Avatar
get some economical saving mods, such as CAI, cam and headers! hahahahahaha
Old 29-01-2006, 09:49 PM   #12
Hitman
Way over here
Hitman's Avatar
Seeing as its only done 80,000 k's it probably won't be the catalytic converter, however it's worth checking it out. My dad's car (AU1) was doing the same thing, incredibly poor fuel economy and sluggish performance, turned out to be a stuffed cat. Changed it, and now it's back to normal.
Hitman is offline   Reply With Quote Multi-Quote with this Post
Old 29-01-2006, 11:41 PM   #13
TwistedEL
TwistedEL's Avatar
As Baboon_AU suggested check the thermostat - i.e make sure it gets up to normal temp when driving. My EL had incredibly bad economy for a while and it was because the thermostat was jammed open so the ECU pumped fuel into the engine to try and bring the temp up.
Old 30-01-2006, 10:09 AM   #14
sbcb
BA Xr8
sbcb's Avatar
Poor economy, my AU2 XR8 auto gets 430km town driving on a 68lt tank. Keep searching for an answer as I had a AU1 futura six and was getting 480ks town driving with the wife at the wheel.
sbcb is offline   Reply With Quote Multi-Quote with this Post
