01-01-2006, 10:59 PM | #1 | ||
I have a 96 ef xr6 and wanted to know if it has the wiring etc. for the climate control, because my mate has one he wants to get rid of cheap.
01-01-2006, 11:08 PM | #2 | ||
the engine bay *might* have the wiring. i know the ED's do as i converted a XR6 wagon and only needed the dash loom and heater box plus various sensors and climate module. if you have the engine loom already then its pretty easy to do.
01-01-2006, 11:15 PM | #3 | |||
Low and Loud
So sorry dude it wont work unless you change your engine / dash and maybe body loom. Isnt worth it really IMO unless your really wanting it like I did
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon : |
01-01-2006, 11:34 PM | #4 | ||
buy a ghia:P
02-01-2006, 12:01 AM | #5 | ||
like i did
02-01-2006, 12:45 AM | #6 | |||
You have to add the wires for the ambient temp sensor and that should be it on an EF, in terms of the engine bay. ECT it gets from the ecu, you will need to install the sun load sensor and the cabin sniffer motor, and it would probably be easiest to hack apart a Fairmont dash loom to get all the wires and connectors. That's how i installed it in the EA, really not that difficult, hardest part is getting the heater box in + out. |
02-01-2006, 01:15 AM | #7 | ||
Low and Loud
And your "attempt" to convert to climate control worked? i seem to remember it not working right lol :P
02-01-2006, 01:25 AM | #8 | ||
Its not that hard, ive done it to my ED. Mostly time consuming.
If you can get the complete heater box and dash from a Fairmont youve got everything you need apart from the ambient sensor. A few people have done it to EF/ELs on Fordmods.com and I dont remember anyone needing to change the engine bay wiring. Certainly didnt need to do it to my ED.
02-01-2006, 12:49 PM | #9 | ||
thanks for the info, don't know if i should put it i or not now
02-01-2006, 04:15 PM | #10 | |||
Only thing that didn't work was the air flow to the face, and that was cos I forgot to connect one of the vacuum lines. :P It's a worthwile mod, IMO, especially at the moment - I just start the car and the a/c does it's thing - fan slows down as soon as the temp is comfortable. Big plus is in winter - your heater doesn't come on until the car has started to warm up - is much nicer than having cold air blow on you. There is a doco on fordmods.com that can guide you through it if you are still unsure. |
02-01-2006, 04:29 PM | #11 | |||
Low and Loud
02-01-2006, 08:58 PM | #12 | ||
MY21.5 Mustang GT
I just finished this mod on my EL XR6...took 2 days to do it right...I bought all the stuff in a "kit" from Ferntree Gully AutoSalvage...they have a forum in the site sponsors section here I think.
Basically I put in a new airbox taken from a CC car, replaced the dash loom with a high series one, added the sunload sensor and ambient temp sensor that sits up front behind the flront bumper. The wiring for that is already there, just a case of plugging it in. Only thing is I need a high series BEM as the LCD dimming doesnt work now and all dash lights are dim, but thats an easy fix...If you are replacing the heater box you need to drain the coolant and refrigerant too.
