Old 07-12-2005, 12:10 PM   #1
AnthonyQLD
Boss power
AnthonyQLD's Avatar
Default H4 Xenon Gas Discharge Conversion Kit
Has anyone put one of these kits ( http://db.hella.com.au/cgi-bin/catal...w&flmaint=2085 ) on there AU XR? How hard are they to install?
thanks in advance
AnthonyQLD is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 03:11 PM   #2
Orbit
Resident Nyctophobic!!
Orbit's Avatar
hmm....since the reflector wasn't designed for HID use i'd be guessing that there will be quite a bit of glare produced. also the hella H4 is for off road only and doesn't comply with any ADR and there fore not legal for on road use, so in my book more trouble then it's worth.
Orbit is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 04:23 PM   #3
AnthonyQLD
Boss power
AnthonyQLD's Avatar
^^^ I was thinking that but just thought i would ask thanks for your help
Old 07-12-2005, 04:27 PM   #4
ilsautomotive
Former E-Series Member
If you were prepared to retrofit HID projectors it could be done properly, but it would take a lot of dedication. I have a similar kit in my Eunos with stock projectors, which is OK but not ideal.
A good link is http://www.hidplanet.com/forums/
Old 07-12-2005, 05:33 PM   #5
Orbit
Orbit's Avatar
the main reason to upgrade to HID is to increase your light, or drop your total amp draw....if you just want looks there are other options for your car that are safer(legally speaking). if you want increased lowbeam contrast ie higher tempreature colour out put from your low beam consider upgrading your car....as the AU low beam is pretty darn good.
Old 07-12-2005, 08:03 PM   #6
AnthonyQLD
Boss power
AnthonyQLD's Avatar
What are the standard globes that were put in the AU's? The ones that are in my AU are crap they have no spread at all. I was thinking of trying the philips vision plus. Does anyone know how well they work?
Old 07-12-2005, 08:42 PM   #7
INJECTED_250
Custom user title
INJECTED_250's Avatar
DAmm.... AU's would have to have the best headlights of any falcon ever.... aslong as youre not driving towards them that is
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 09:11 PM   #8
galaxy xr8
Giddy up.
galaxy xr8's Avatar
I agree, the AU light's are very good.
Old 07-12-2005, 09:31 PM   #9
Lukeyson
Right out sideways
Lukeyson's Avatar
i know what your meaning 'ahhhh my retina' is what i scream every AU i pass at night
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2005, 10:02 PM   #10
Orbit
Orbit's Avatar
narva artic's are prett ygood and the philips are pretty good too.
what are your reflectors like? there might be more problems then just your globes
Old 08-12-2005, 04:10 AM   #11
bigred
Ford lover
bigred's Avatar
I have a set of bi-xenons H4's in my AU2 Ghia. They do the high beam, by using an actuator thats part of the bulb.
They are the retrofit kit as seen on ebay and hella. I just make sure that I have the main bean probably a little bit lower than the correctly aimed setting to accomodate the power of the xenons.
As for the police, I have had these bad boys in for about 2 days, and driven past 3 coppers, and noone had a poblem, even when I was following one for a brief period.
They look great though and the light is awesome.
bigred is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2005, 08:44 AM   #12
The Dok
The Dok's Avatar
The AUXR come std with H4 60/55 (dual filament) globes. Also they have a metal reflector body & glass lens (totally inseperatable) therefore making any modification virtually impossible. My advice would be to install Philips Crystal Vision or Blue Vision 60/55 watts. Using a higher wattage in these headlights (or any for that matter) only results in overloading/overheating the electrical system & burning of the reflector surface. :
Removed by laminge
The Dok is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2005, 10:55 AM   #13
ilsautomotive
That is true, but blue-tinted bulbs of any sort generally have the same heat issue as they try to immitate the pure white light of 4300k HID. The tint creates a whiter light by reducing the yellow from the spectrum, but of course that energy is turned into heat and effectively means reduced output and increased wiring/reflector damage.
Old 08-12-2005, 11:00 AM   #14
Orbit
Orbit's Avatar
big red. do you have any pictures or more specs?
Old 08-12-2005, 11:57 AM   #15
AnthonyQLD
Boss power
AnthonyQLD's Avatar
How do those lights go in the wet? I have heard that the whiter lights reflect alot in the wet!
Old 08-12-2005, 12:26 PM   #16
Orbit
Orbit's Avatar
they are fine in the wet. i had them in mine driving to lismore when they had 26inches in 24 hours or somethign stupid like that earlier this year and they were fantastic
Old 08-12-2005, 12:45 PM   #17
AnthonyQLD
Boss power
AnthonyQLD's Avatar
according to Philips the Crystal vision is not approved for road use! has anyone ever had any trouble?
What type are the highbeems in the AU? H1 or H7?
Old 08-12-2005, 03:34 PM   #18
The Dok
The Dok's Avatar
I have Philips Blue Vision in 1 of my vehicles (AU) no problems in the wet here either. AU highbeam is H1.
Removed by laminge
Old 08-12-2005, 04:24 PM   #19
AnthonyQLD
Boss power
AnthonyQLD's Avatar
Do you have blue vision in your highbeam to?
thanks for all the help people :eclipsee_
Old 08-12-2005, 06:10 PM   #20
The Dok
The Dok's Avatar
No........didn't see the need as most of the driving I do doesn't require the use of high-beam.
Removed by laminge
Old 08-12-2005, 08:05 PM   #21
romaniac
holla at cha boy
romaniac's Avatar
im using phillips diamond vision, great light and no problems from police
romaniac is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2005, 08:52 PM   #22
Orbit
Orbit's Avatar
i've got them in both.....and lots of other big lights as i do most of my driving in the middle of knowwhere at stupid oclock.
like DOK said, if you don't need them don't worry abou them
Old 08-12-2005, 09:33 PM   #23
AnthonyQLD
Boss power
AnthonyQLD's Avatar
Philips say that Diamond vision has less intensity to a standard globe. Do you find this to be a problem? They are also a 5000K colour so I presume that they are very white/ blue????
Has anyone tried the Vision plus globes.
philips say up to 50% more light on the road in low beam and 10-20m extra on high beam.
Old 08-12-2005, 09:51 PM   #24
luke
UITABLE FOR OFF-ROAD APPLICATIONS ONLY. NOT ADR COMPLIANT OR LEGAL FOR ROAD USE. Fitment and use is only permitted for H4 headlamp systems with integral globe shield.
Shouldn't matter anyway? Off road my a**
2003 BA XT Wagon, I6, 4sp Auto, Dual Fuel, Prins Autogassystemen VSI LPG
RIP:
EA S MPFI 5 speed sedan w/exhaust, LSD, tint, 225's, DBA Golds, EL twin thermos, dual fuel and fluffy dice ; Stolen, recovered and written off, 7th April 2007
luke is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2005, 01:38 AM   #25
romaniac
holla at cha boy
romaniac's Avatar
nope, i found them to be brighter than my normal lights. The light is a white/blue yes.
Old 09-12-2005, 11:17 AM   #26
Duffman
Oh Yeah!
I was going to get some of those narva vision ones that are surpose to put out 50% more light for my au2 forte. Will they actually put out that much more light without hurting other peoples eyes?
Oh no! Duffman can't breath! Oh, yeah!
Duffman is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2005, 11:45 AM   #27
AnthonyQLD
Boss power
AnthonyQLD's Avatar
That is what I want to know about the Vision plus globes. I would think if they are Approved for raod use then they cant be to bad on other drivers eyes.
The vision plus would still still have a whiteish look about them being 3500K. Standard globes are only 3200K
Old 09-12-2005, 12:25 PM   #28
Orbit
Orbit's Avatar
yep they are no worries, remember there is a difference between intensisty of light out put and the quality of the light(ie colour)
Old 09-12-2005, 11:10 PM   #29
HLC
Audi S3
im Using Narva Arctic Blues and they are fantastic. gonna put em in my mums 'lane and dads XR too. im stoked with them.
Old 10-12-2005, 08:51 AM   #30
Mechan1k
Mechan1k's Avatar
I've had my JSM Bi-xenon kit in my ute for over 6 months now ... I drive during the day with low beam on (i'm a courier and prefer to drive with lights on all the time for safety) ... I pass so many Police it is not funny .... I have not been pulled over at all.
Mine run at a colour temp of 6000K ... and kinda look blue ... more white than anything at night though ... I also have adjustment set down a bit as well to reduce glare.
But they are not ideal though ... hence why I will be retro-fitting HID projectors into my aftermarket AU headlights soon ... when money and time permits ... then I will have a perfect flat top beam with no glare whatsoever.
Mind you I was flashed by a Bombadore last night (after he flashed the VW Touareg (with HIDs) further in front of me .... they VW driver flashed him back ... so he decided to flash me as well ... poor bastard didn't realise I had a set of LightForce 240 Striker driving lights on the front of the ute as well. ... I think he was seeing stars/spots/was blind after I flashed him back.
Hope that taught him a lesson.
