Old 24-10-2005, 09:02 AM   #1
hockings
Default Replacing the sump - AU2-S
I've got a cracked sump and need to replace it. I do my own regular serving (changing the oil etc) and am reasonably handy - does anyone know if it's difficult to replace your sump? I'm hoping it's just drain the oil, undo some bolts, remove the sump, grab a new (2nd hand) one with a gasket of some type and bolt it on.
Is that about the size of it and is it relatively easy to do?
Thanks!
Shane
hockings is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2005, 10:33 AM   #2
AUII_Forte
AUII_Forte's Avatar
Nope, infortunately not that simple.
You either have to pull the motor out or drop the K-frame. There isn't enought room to get the sump out with the engine and k-frame in place.
2003 Narooma Blue BA XR6 5spd Manual.
Pacemaker 4490 Extractors
2.5" Exhaust
High Flow Cat
SS Inductions "Growler" CAI
Underdrive Pulley
Mal Wood H/D Clutch
Custom Tune
18" XHP Sabre's
12" Kicker Sub
169.2 rwkw
AUII_Forte is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2005, 04:24 PM   #3
xr8 007
xr8 007's Avatar
You serious!!! Ouchhhhhhhhhhh
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2005, 07:24 PM   #4
EvilChief
Boost Addict
get and angine cran and pull the bolts out of the engine mounts, leave the transmission in place and transmission mounts attached. then pull the engine up and you should be able to sqeeze it through, its tight but doable. when new sump in place drop it back down into its place and put the engine mount bolts back in ... done
N12 Pulsar - sold
Gen1 Liberty Turbo - sold
VP Commodore Turbo - sold
LN65 Hilux Turbo - sold
EL31 Corolla Turbo - sold
Ford AU Ute Turbo - sold
Ford FG XR6T Sedan - cruiser
