Old 19-10-2005, 02:17 PM   #1
cjsarg
Default AU 2 shuddering
I have a problem with my 6 cylinder AU 2 it shudders sometimes when taking off or sometimes when just cruising at 100k it will shudder a bit like gear box slipping but not sure any help i would be very gratfull.
Old 19-10-2005, 02:21 PM   #2
klawsterfobik
Bad Music and Litre Bikes
klawsterfobik's Avatar
i just had the same thing in my car. Turned out the MAF sensor was buggered. I took it to the mechanic, he plugged it into a machine and told him that it was stuffed. cost me $35 for the test.
might be worth looking at.
XY Wagon - NAKED!
Originally Posted by Gammaboy
Anyway. Enough reality, back to the topic.
klawsterfobik is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2005, 04:49 PM   #3
AU:PROJECT:UTE
Drought Breaker
AU:PROJECT:UTE's Avatar
Is your engine shuddering?; ie missing or is it hesitating?; ie not feeling like it wants to rev normally under load?
If its hesitating I'd suggest you might have a dirty fuel filter, I'd check this first as it is a lot cheaper to replace than a MAF sensor, and will cause the engine to starve and jerk and not accelerate cleanly.
2002 AUIII XL W/- Custom Tray
ALL COUNTRY: SW Platt Mccann 5 Poster, GME 4706 7' Whippys, Uniden UH015SX UHF AND Scanner combo, Narva Taurus Bull lights, Hawk Grille, Series II Pursuit Side Skirts, Stickers on the back window and more eartags than a mob of cranky angus
ALL GO: XR6 VCT donk and ECU NO MORE!!
Now even MORE fun with 200kw XR8 and 5 speed, Tickford Cluster, 3.45 LSD, full custom twin system w/- 3" chrome angle cut tips :
AU:PROJECT:UTE is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 10:13 AM   #4
Moya
dirty fuel filter
dirty air filter
couple leads gone? (shes may only be firing on a couple less cylinders)
sparks?
Moya is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2005, 12:06 PM   #5
cjsarg
Replaced Fuel filter seems better will check leads also as still has a slight shudder
Thanks everyone.
Old 20-10-2005, 10:28 PM   #6
HLC
Audi S3
either my ED or AUII did that a couple of times. always when i had the music blaring. like it was starving of fuel. for the life of me i cant remember which car though :|
Old 26-10-2005, 11:16 AM   #7
cjsarg
Change spark plug leads.***** of a job.but it has rectified the problem .
thanks
Old 26-10-2005, 12:28 PM   #8
GlennBA
GlennBA's Avatar
mine shudders when i take off quickly then back off the accelorator sometimes.
GlennBA is offline   Reply With Quote Multi-Quote with this Post
