Smile
Just say that there are 2 identical cars and both are doing a 1/4 mile.One is a manual and one is an auto. Diffs are the same. Which car will get to the line quicker? Are there any manual shifting for the auto to get it moving? Where is the disadvantage and advantage?
Any tips?
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() |
PM me if you want
Assuming both drivers can drive the cars the optium in shift speed and gear change.
The manual has less loss through the drive train, and better gearing, so should win.
Smile
Where is optimum shift point?
PM me if you want
The optimum shift point is when the car has reached max power for the gear and engine (well just before to allow for lag).
Last warning
well.. no
optimum shift depends COMPLETELY on power curve. manual is better until we're talking high HP.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
they call me Tibbo
every 'Wheels' type test has the manuals .5 of a sec quicker over 400m
Smile
So let the auto create max torque multiplication down low then manually shift through 2 nd and third?
i'd say the manual is faster depending on driver.. if both cars are resonably stock
and my idea of optimal shift point in an i6 would be about 5,600 or a little more.just before revlimit, so when you change gears, it drops the next gear right into the power band.. where as when you change end of power band it will drop the revs of the next gear below the power band and then having to work its way back into the power band would make it slower well thats my opinion |
Smile
Do you think that the fact that each of my gears start at 3200-3500 rpm now help my situation?I have found the manual much more consistent in power delivery that mu auto.Sometimes I fang it and it just keeps going other times it seems a bit laggy.I think its the torque request engine control function on pin 6 of all AU ecus.To top it off a knock sensor which kills timing.
Smile
btw Stiddy I reckon your a top bloke mate.
#11 | |||
but a shift kit and a stally the auto will kick **** . |
#12 | ||
you sure about that Nik lol yes the stally and shift kit helps but i wouldnt say kicking ***..
and useless yeah was good this morning, great to meet ya.. gotta do it again where does your auto shift at useless, what revs? |
![]() Join Date: Dec 2004
Useless, given all AU's have the same auto ratios and assuming you change at the 5500rpm redline, these are the revs ALL AU autos do....
From 1st to 2nd revs drop to:3,337rpm From 2nd to 3rd revs drop to:3,793rpm From 3rd to 4th revs drop to:3,740rpm
#14 | ||
sweet thanks casper, but as far as i know stav just leaves it in D and goes.. so i dont think its getting to 5500rpm..
so when it shifts its probably dropping below its power band.. thats just at a guess, not sure if the stall alters this or not but it scoots off the line resonably quick for an au wagon.. was suprised when i was in it this morning.. |
#15 | ||
Smile
Stiddy I am not sure what rpm it shifts to...In first but definately up to 5200 rpm.
As you saw today my auto ..when it feels like it, goes like a frighteningly like a rocket and other times seem a bit flat.I think it doesnt help with around 220 kgs in the back boot with cargo barrier either.However when it does take off as you saw it was pretty good. Keeping up with a manual which weighs 50 kgs less from factory and without the excess 220kg boot baggage I had .Its like having 3 guys in the car. Youve got to admit..allowing for this that it went well. I will be checking rpm points soon and let you know. Will meet again bud. Stav
#16 | |||
Smile
Stiddy you have a very sexy xr6 man...it looked aweso.me
#17 | ||
i think if you stall it up off the line to liek 2500 - 3000 and let it go and hold it in gear till 5500rpm every gear it will be fairly fast..
haha thanks man, its a pretty nice example.. |
#18 | ||
Smile
ANd lose the excess weight ......I am experimenting with locking in 3rd gear via ecu.
#19 | ||
[QUOTE=stiddy]you sure about that Nik lol yes the stally and shift kit helps but i wouldnt say kicking ***..
yeah i may have got a bit excited ,but they definately make a difference compared to a stocko auto . i'd still prefer a manual though so dose nik |
#20 | ||
___________
I have an Auto AU1 and my brother has got a manual AU1, and I would say the manual is much quicker simply because the car puts more power to the ground.
My car has exaust, extrators and hiflow cat and I managed 15.6 and my bros with just a 3.7 geared LSD diff managed 15flat. But I like my auto for day to day driving and the odd squirt, but if you are looking for performance, Manual is the go. |
#21 | |||
Smile
#22 | ||
Smile
So has anyone in their real life experience shifted manuallly in an auto and what are your recommendations please? Are the results that much better?
#23 | |||
Smile
#24 | |||
XB in parts...
Daily Driver 2019 Ford Escape...looking for XR6T's. Last edited by loxxr6; 14-10-2005 at 10:01 AM. Reason: spelling |
#25 | ||
Solution Was Boost 4?, 6 & 8
The manual you can launch of the line harder.....good 60 foot makes a good ET..
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
#26 | ||
Right out sideways
bad example, but my wifes AU2 xr8 auto sedan Vs my AU2 XR8 manual ute, her car is quicker. But ute is near 100kg heavier
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302 |
#27 | |||
I'm not the best at it, but i was pretty impressed with my times, and the car was cold cos I had to wait about half an hour before they cleared the track of a spill. I hope that helps. ![]() |
#28 | |||
Smile
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again ![]() Last edited by Stav; 15-10-2005 at 05:37 PM. |
#29 | |||
TL40 Wagon?
#30 | ||
i was pretty happy with how it went on friday night, considering i had half a tank of fuel, a spare tyre, and my far **** in the car when i did it!
i was told that apparently if i had let my tyres down i would have been able to defeat the wheelspin off the line? and should i have been stalling it higher aswell? i just wanted to get an idea of how quick it is stock so that when i eventually get enough money up to do upgrades, i know what i have gotten for my money. but that probably wont be for a while. |
