Old 30-09-2005, 04:55 PM   #1
Cheap AU
Column Shiftin'
Default little help
the lcd display globe needs replacing... how would i go about getting to the little 2 watt globe and is their anything special that i should watch out for or sumthing that could be broken easily in the process?
thanks
Cheap AU is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2005, 07:15 PM   #2
Scruba
15+ Years!
Scruba's Avatar
check out the workshop @ aufalcon.com
i recently had the same problem. make sure you change both of them. i did one at first and the older bulb was dull so I put 2 new ones in.
very easy to do.
AUII Fairmont Ghia Sedan Sparkling Burgandy
Work in progress
https://photos.app.goo.gl/7roViz57bb2Stkzx6
Scruba is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2005, 07:28 PM   #3
Cheap AU
Column Shiftin'
i cant find an article there thats going to help me?
i need to take off the dash i think and get behind the instrument cluster and speedo to change the globes that light up the lcd display
Old 30-09-2005, 07:34 PM   #4
Cheap AU
Column Shiftin'
whoops im blind i found the removing the instrument n dash cluster..... thanks
