Old 19-09-2005, 04:06 PM   #1
Nik
Default ilde issuse's with big cam i6
i was thinking about getting a custom grind done for our au2 falc .is there anyway other than getting a chiptorque chip to get it to idle? i don't realy want to go through the dramas of pulling the unichip out and getting a chiptorque .
i remember reading on a forum somewhere that some had suggested to drill a small hole in the butterfly of the throttle body to help keep the idle up .do you reckon this would work or not?
thanks jake
Old 19-09-2005, 04:27 PM   #2
Walkinshaw
Two > One
Walkinshaw's Avatar
The unichip should beable to tame down a cam to a level where an acceptable idle is achieved. Just get the unichip retuned when the cam goes in.
Old 19-09-2005, 04:31 PM   #3
xr8ute
Back on the road
xr8ute's Avatar
Bigger cams generally want more air at idle. The way EEC handles this is by changing the duty cycle of the ISC.
There is probably a Jaycar kit you could use as an "interceptor" between the EEC and ISC to add more duty cycle at idle.
Or you could drill a little hole in the throttle butterfly.
BTW, you can run both a Unichip and Chiptorque if you wanted. The Unichip is not actually a "chip", it's a piggyback computer.
Old 19-09-2005, 04:47 PM   #4
Nik
i will be over at g and d performance on thursday so i will ask them what they can do with the unichip regarding the idle .
xr8ute were would i go to enquire about one of these jaycar kits ?also if i was to drill a hole in the butterfly what size would you reckon i should start with first 3/4 mm.how would this affect setting the base idle ?
thanks jake
Old 19-09-2005, 05:15 PM   #5
Stav
Smile
Stav's Avatar
Jake my dev 4 cammed car idles excellent.It idled a bit rougher before and the problems areas were the orings and or injectors.The next probllem area are the lifters.The shimm Jmm are not the ultimate.Pm me for some advice.
Old 19-09-2005, 06:02 PM   #6
xr8ute
Back on the road
xr8ute's Avatar
See what G&D recommend before anything else. How big is your cam?
As Stav was saying, make sure the condition of the rest of your engine is in good nick. With a larger cam, your engine will be less tolerant of things like worn plugs, leads, injector O-rings, inlet gasket leaks etc....
Old 19-09-2005, 06:09 PM   #7
xr8ute
Back on the road
xr8ute's Avatar
I wouldn't be 100% sure, but if anything works, it would be the Jaycar Digital Pulse Adjuster (needs hand controller kit also).
http://www.jaycar.com.au/productView...=&SUBCATID=347
Old 19-09-2005, 06:19 PM   #8
Nik
there's nothing wrong with the idle at the moment and the engines still in good cond.i have just had a head ported out and was looking at getting a custom grind done up . i just wanted to make sure i can get the thing to idle.
i will be fitting the head wednsday and hopefuly it should idle alright .
i will have a yarn to g&d first and then go from there .
thanks
jake
Old 19-09-2005, 06:53 PM   #9
Stav
Smile
Stav's Avatar
Good luck with it Jake.
Stav
Old 19-09-2005, 07:45 PM   #10
SpoolMan
Solution Was Boost 4?, 6 & 8
SpoolMan's Avatar
we have had a 222@50 cam idling fine with a Unichip and 2500 rpm stall in a AU6..
good tuners can make a big difference in your idle quality, get a dyno tune which ever way you go..
your in QLD a quick trip to Lochlan's shop would get you a custom dyno tune.
[SIGPIC][/SIGPIC]
SpoolMan is offline   Reply With Quote Multi-Quote with this Post
