Formally ED I6
My EA air con this week suddenly decided it doesnt want to work
![]() I ran the climate control in diagnostic mode and the cabin temp reading is stuck at 0.0°C ![]() Would this cause the air con to not work, or is it more likely a gas problem? Is the cabin temp taken from the sniffer motor or a sensor somewhere else?
Daily driver 98' AU 349ci Fairmont Ghia on LPG --------------------------- Other 93' ED 5spd 4.0L NA Fairmont 13.75 @ 101mph |
i got an ebII so i'm not sure if im even on the right track but when my air con died it was just a little black vaccum hose... i think very skinny..i don't even know what i plugged it back into but it works now haha
i think you are on the right track gozza
If the sensor is faulty, it should have a default reading. Are you sure this is 0.0°C? If it's on the coldest setting, 16°C, it should work anyway. If it's sudden, I wouldn't think it's a gas problem.
#5 | |||
I reckon the sniffer motor might be the issue, pity, I just threw one out. Though it should still work, just not that well in auto mode.
Any air bubbles in the sight glass? Gas in the system? Clutch engauging? is it using R134a or R12? Quote:
#6 | |||
Formally ED I6
At the moment I'm thinking either the sniffer or a seized compressor (damn lpg setup is in the way of looking at the compressor). Anyone priced a new sniffer motor from ford? R134a or R12?? Not sure what you're asking.
The gas in it, do you know if it's R134a or R12? Being regassed 3 months ago it should be R134a, possibly HC though. They show up differently in sight glasses.
![]() Join Date: Oct 2006
Was this solved?
I have a similar problem on my NB Fairlane. The Cabin Temp sensor is also showing 0.0°C all the time. The sniffer motor is working and the sensor is connected but I have a choice of freezing air when the Climate control is et to 16 degrees or max hot air at anything from 18 degrees upwards. It will intermittently behave and work correctly for a few kms/minutes but most of the time it's useless.
regards Blue |
#9 | |||
BTW can anyone confirm the test details here are correcxt: http://www.fordmods.com/documents.php?d=9
regards Blue |
Fixed. Looking inside the sensor I see shiny drops of liquid which doubtless has shorted the thermistor contacts - the missus confessed in cleaning the interior she sprayed the dash including the sensor sniffer motor grill with Mr Sheen. A spray inside the sensor with some rf (Robert Foot Pty Ltd) Electronic Cleaning Solvent No 1 (fast drying no lubricants) from Altronics has it all working perfectly again.
regards Blue |
My EB climate control has been doing the same thing lately, max cold or max hot only. Did you spray the electrical cleaner into the grille or did you have to remove the sensor?
#12 | ||
Into the back of the sensor; took the little duct off between the sniffer motor and sensor. You could spray it through the grill but leave the car off until it drys out as if the electronic cleaning fluid gets into the sniffer motor it could kill its bearings.
regards Blue |
Be generous with the cleaner from what washed out a lot of dust also collects in the sensor which can't help it work.
regards Blue |
#14 | ||
They probably end up like this (well worse given the age difference of the cars) one in a Lexus which uses a similar setup:
see http://forum.ih8mud.com/100-series-c...mp-sensor.html
regards Blue |
#15 | ||
I just had the painful experience of replicating this issue when pulling the dash to fix another issue (fixing a mount that I broker when cleaning the sensor). If you don't plug all the climate control plugs at the back of the control unit fully in you can get the same issue (even though they may look properly plugged in one apparently wasn't fully seated). Of course I thought it was a dirty cabin sensor again and from this I can advise:
a) spraying into the front grill won't achieve much; b) removing the friction fitted sensor risks breaking one or both mounting pins (I broke one); and c) the difference in this case is that the sensor signal could be turned on and off by thumping the top of the dash gently. Tracking the wires from the sensor and checking the restance readings with a multimeter had me convinced it wasn't the sensor this time but it was only when I slipped and knocked the dash that I had a clue to the cause. Knocking wires and connectors made no difference but tapping the control unit did. I think it was the white plug that was loose but in any event unplugging all three connector from the back of the control unit and plugging them firmly in again fixed it and no amount of thumping brings it back.
regards Blue |
#16 | |||
#17 | ||
On EA/EB series behind the little grill above the coin tray and clock/trip computer. On the ED it's incorportaed into the Automatic Climate Control Switch Panel.
regards Blue Last edited by aussiblue; 12-04-2013 at 11:11 AM. |
#18 | ||
Since my post above I re-ran the diagnostic routine and got the "OFF" result.
Director, Finance and Planning then went shopping and on the way home the AC failed again i.e. fan slowing down and hot air in the foot well. Something quite intermittent - gnashing of teeth! Last edited by Guess_who; 12-04-2013 at 01:04 PM. Reason: Added "then" |
#19 | ||
Intermittent with an E3 suggests that either the two pin connector in the harness at the sensor is bad or poorly connected or the connector at the back of the control panel is not fully seated. I got no E3 codes.
regards Blue |
#20 | ||
I replaced the climate control panel some time ago and everything worked for a short while.
As you stated in an earlier post maybe the connectors are not properly seated. In the interim, before I came across this thread, I have purchased another climate control panel which should arrive towards the end of next week so will hold off doing anything until then. |
#21 | ||
Typical! The weather has now turned cool.
I couldn't wait for the climate control to arrive so I partially undid the screws to have a look at the cabin sensor -hmm, it all looked too involved particularly what appeared to be the sensor mounting - so decided to do everything back up. As suggested earlier I gave the three plugs on the climate control a really good press to try and ensure a good connection. After a very short test all seems to be good. Wait and see ... |
