Old 05-09-2005, 03:41 PM   #1
b2tf
not here much anymore
b2tf's Avatar
Default AU2 Knocking in front end
I know this should probably be in the tech areas but im more in need of info from AU owners, hence I posted it here.
Dad's AU2 has a very odd knocking/creaking kind of noise coming from the front passenger side at low speed. It seems to happen when steering and also when going over rough surfaces, so Im thinking either shock absorber or possibly the charcoal canister? (I think thats what they're called?) rubbing against the panel.
If it is this, whats the best way to get in there and check? It is a case of removing the wheel well splash shields and getting in there?
RAM 1500
Old 05-09-2005, 05:57 PM   #2
Stav
Smile
Stav's Avatar
If it sounds like a dook ,dook, dook sound then its your shocky mate.
Old 05-09-2005, 06:37 PM   #3
sbcb
BA Xr8
sbcb's Avatar
I'll follow this thread with interest, mine has developed this low speed knock noise while slowing for a intersection etc. Quite a dull noise but obvious with the radio down. Seems to be on the front passenger side, problem is that it is a very inconsistent noise to produce. Only pattern I seem to notice is that it is only noticeable when the car is warmed up. Have tried recreating the noise while boucing the cars suspension in the garage but have not been able to reproduce it. I was starting to think it was releated to brakes, definitely not consistent like what I would expect a shock/road bump noise to create.
Mine is a AU2 XR8 auto.
sbcb is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2005, 06:56 PM   #4
mattsAU1
mattsAU1's Avatar
i had the same prob with mine bout 12 months ago and took it to pedders for one of those $14 suspension safety checks
turns out mine was a couple of upper ball joints and a cactus rack and pignion
ended up sosting me a pretty penny too
hopefully it doesn't cost as much for you and it is a no obligation analysis of all the suspension components of your car so for $14 its was a good idea and i take mine back every 10000kms or so for a checkup
being no obligation if your confident enough and have the right tools etc do it yourself and save on labour
mattsAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2005, 07:52 PM   #5
bailey04
RockGod
bailey04's Avatar
Thats exactly my thoughts.. Mine makes the same noise and its an AUII SR..
Some days the noise is there other days it not..
Maybe taking it to pedders will be the way to go.
bailey04 is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2005, 07:53 PM   #6
Tickford Kid
Formerly known as TS 50
Tickford Kid's Avatar
Upper ball joints can become dry. This will give the sensation that the front shocks are stuffed and make a thudding noise a low speed. Peel the boot back and lubricate the joint.
Found this on a mates TE50.
BLUEPRINT T3 TS50 #109, MANUAL WITH BREMBOS
Tickford Kid is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2005, 07:55 PM   #7
mattsAU1
mattsAU1's Avatar
$14 bucks mate it was the best money i ever spent
my rack was shagged like completely empty of fluid
who knows what would have happened i was like the guy reckons bout a couple hundred kays away from frying my power steering pump and they not cheap at all
there is nothing wrong with mine now i just take it back for my own peace of mind
Old 05-09-2005, 09:14 PM   #8
AUXRVIII
Ford dealers have a special tool for greasing the upper ball joints from AU onwards.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2005, 09:18 PM   #9
jonbays
TL40 Wagon?
Mines the same and it was upper ball joints too. Not stuffed but dry. They couldn't have packed them with grease properly from the factory.
It made a slight rattly noise at walking pace coming to a gentle stop. But you couldn't find it by bouncing or rocking the car.
Old 05-09-2005, 09:24 PM   #10
b2tf
b2tf's Avatar
Thanks for all the replies guys, it definately sounds like upper ball joints are worth looking at.
The Pedders check is something Ive told Dad to have done anyway since this came up, so we will definately get it done but its always good to have an idea of what to look for yourself beforehand.
RAM 1500
Old 06-09-2005, 12:21 AM   #11
JC
JC's Avatar
That's why you should check your power steering fluid level at least once a month.
Ford Performance Club ACT
Old 06-09-2005, 06:13 PM   #12
sbcb
BA Xr8
sbcb's Avatar
All good feedback cheers all.
Old 06-09-2005, 07:07 PM   #13
b2tf
b2tf's Avatar
Thanks for this but can you go into a bit more detail? Im a bit lost as to where to start having never done anything like this before.
RAM 1500
Old 06-09-2005, 07:54 PM   #14
Tickford Kid
Quicker and cheaper in the long run for you to take it to a Ford dealer that has done this before. Upper control arm has to be removed.
Sorry i can't be more encouraging but steering and brakes should be left to mechanics.
Old 06-09-2005, 09:06 PM   #15
b2tf
b2tf's Avatar
No dramas - I agree about brakes and steering. It wont be going to Ford though.
RAM 1500
Old 06-09-2005, 09:50 PM   #16
hawke
hawke's Avatar
I had a similar problem. I found that some of the top strut nuts were a little loose, and a tighen up of someother suspension bolts did the trick.
hawke is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2005, 12:15 PM   #17
mattsAU1
mattsAU1's Avatar
roger that i wouldn't take my car to ford either Pedders i reckon is the go at least they have rebuilt parts that they put a fairly significant warranty and replacement on
ford will have warranty too but it will be brand new parts and cost twice as much not to mention labur costs
Old 08-09-2005, 09:52 PM   #18
FTGAutosalvage
Commercial Sponsor
FTGAutosalvage's Avatar
i had the same problem on one of the delivery utes.
found the sway bar was loose at the links where it joins the lower control arm
apparently it is a common problem.
FTGAutosalvage is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2005, 09:59 PM   #19
b2tf
b2tf's Avatar
Ah - reminds me to update this.
Dads had Pedders give the car a once over and they reckon the bushes need replacing, and also found a power steering leak (unrelated).
They also quoted on a full steering rack replacement which is totally unneccesary and has me of the opinion that they may be just fishing for work, not sure.
Going to have the regular servicing mechanic take a look at it at next service and get a second opinion.
RAM 1500
Old 09-09-2005, 01:17 PM   #20
FTE217
T3/Sprint8
FTE217's Avatar
Believe it or not I don't check a thing unda the bonnet. If there's no oil stains on my driveway I can't see the point lol.........97000 clicks and still no leaks anywhere.
The only time the bonnets up is in at Ford service time (touch wood : )
Tickfords T3/TS50 '02
Sprint8 manual Sept 24 '16
Daily Macan GTS
"Don't believe everything you read on the internet. Abraham Lincoln"
FTE217 is offline   Reply With Quote Multi-Quote with this Post
Old 11-09-2005, 11:17 AM   #21
Mechan1k
Mechan1k's Avatar
Sounds like they were fishing for work.
I just had my power steer hose replaced from the rack to the pump/reservoir ... not the cheapest item (just over $100 for the pipe) ... but if i didn't get it replaced it would have killed my recently replaced alternator (as it died 2 days before I was going to replace it anyway.
I am going to get a suspension check just to be safe as well ... I here the odd clunk at slow speed when turning sometimes ... might just be the dry ball joint issue ... but want to get everything else checked out.
Old 11-09-2005, 11:02 PM   #22
Velociraptor
Digging for avatar
A second opinion is a good way to go , its very hard to find a mechanic you can trust. My AU was making a noise like you describe , it was a loose rack : before I had the "dreaded rack recall".
was extinct but got better.
Velociraptor is offline   Reply With Quote Multi-Quote with this Post
Old 04-11-2005, 06:58 PM   #23
sbcb
BA Xr8
sbcb's Avatar
Mine fixed, upper ball joint, cheers team.
