ASL
Old 12-01-2025, 12:40 PM   #1
james22
With da Warlords
james22's Avatar
Default Broken fuel cap removal
Any ideas anybody?
Outer cap has separated from inner part which is still screwed into fuel filler. FG
Doing my head in...
TIA
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 12-01-2025, 01:38 PM   #2
james22
With da Warlords
james22's Avatar
Default Re: Broken fuel cap removal
Few more curse words, and an hour later I got the bloody thing off :-)
Windsor Warlords
AU III XR-8220
Old 17-01-2025, 08:07 PM   #3
Crazy Dazz
hold a match to it, and blow it off
Crazy Dazz
Kicking Hippies in the Balls since 1966
Old 23-01-2025, 08:05 PM   #4
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
Had this a couple of times lately, just gotta tap the bit inside the pipe around with a screwdriver or similar. There seems to be a 10 year lifespan.
Next to go will be your radiator cap.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2025, 09:58 AM   #5
bangm001
Mopar! But Own F6's..
Do ford still make these?
F6 TYPHOON
FPV 335 GT
bangm001 is offline   Reply With Quote Multi-Quote with this Post
