Old 01-10-2020, 09:09 PM   #1
thedom4302
Default Focus 2007 LT reverse wire
Hi,
bought a reverse camera for my focus 2007 Sedan LT and just wandering if anyone knows if i can tap into the reverse signal wire from the front of the car rather than pulling it from the back light assembly?
D
thedom4302 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2020, 11:04 AM   #2
marg99
Default Re: Focus 2007 LT reverse wire
if it is a manual you can use the reverse switch on the gearbox
Old 02-10-2020, 11:28 AM   #3
thedom4302
yaaaaas it is
and where is the reverse switc?
Old 02-10-2020, 12:15 PM   #4
marg99
on my tdci it was on top of the box mid way along slightly toward the front has a two wire clip on it
Old 02-10-2020, 04:10 PM   #5
leakey
leakey's Avatar
Lots of fun to get to on petrol version.
I'd stick to the wire at the very back, under the rear bumper lip. use a cable splicer.
Couldn't tell you where that leads at the front of the vehicle.
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2020, 05:19 PM   #6
11ford11
Run reverse lights wire with camera cable to rear and connect to reverse lights -some camera cables already have reverse cable already in the same cable next to the connecting plug
11ford11 is offline   Reply With Quote Multi-Quote with this Post
