Old 01-10-2020, 09:57 AM   #1
gutza
Default How Strong are Jack Stands
Hi Guys.
Obviously, over the years, there has been recalls on Jack Stands and Trolley Jacks. Also, I guess, you get what you pay for as well.
Accidentally came across this YT Video this morning ......
https://www.youtube.com/watch?v=GjmXQNhKCks
Also on the same channel, this one, which included a Trolley Jack.
https://www.youtube.com/watch?v=7_fqF09QQjc
Cheers.
gutza is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2020, 10:14 AM   #2
PG2
#neuteredlyfe
PG2's Avatar
Default Re: How Strong are Jack Stands
Originally Posted by gutza View Post
Hi Guys.
Cheers.
As they say, never get under a car only supported with a jack.
I suppose nothing is 100% and anything is only as strong as it's weakest link.
PG2 is online now   Reply With Quote Multi-Quote with this Post
Old 01-10-2020, 11:05 AM   #3
Tonz
or stupidest
Dont p i s s off older people. At our age the term Life in Prison is not a deterrent
Tonz is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2020, 09:47 PM   #4
happy1
I buy the 4-ton jack stands, and I buy the oversize trolley jack as well, at least double the capacity of what I try to lift. I never stick as much as a foot under the vehicle until I have jack-stands, or wheels and wooden blocks etc, under the car.
When I jack up to take off one wheel, I have the habit of putting the wheel immediately under the door sill, (and add a plank or a brick to take up the gap). That way the car can't fall far.
Cheers,
happy1 is offline   Reply With Quote Multi-Quote with this Post
6 users like this post:
Old 04-10-2020, 10:06 PM   #5
Crazy Dazz
Forget the jack stands
Now I just want to buy one of those Hydraulic Presses
Think of the hours of family fun squashing annoying **** and posting it on youtube.
Imagine all the crap that I could post back to the manufacturer, in an envelope.
Making Whine from the Tears of Hippies
Old 04-10-2020, 11:44 PM   #6
oldel
Anyone got a welder? I want to make these
https://www.youtube.com/watch?v=1-tOi48FsoU
Of course I wish I could buy a mini 4 post like m539 restorations. https://www.youtube.com/watch?v=FgIDBw8ELTQ
oldel is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2020, 10:12 AM   #7
Pis-ton broke
Pis-ton broke's Avatar
does he take the jacks back to supercheap and ask for a refund?
Pis-ton broke is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2020, 11:41 AM   #8
Tassie f100
Wonder how much welder and grinder slag spots finished up with on the side and front of the black car?? Brother in law built some like years ago but he had the pivot point much further back,so when you drove up onto the ramps the car went past the centre and the front dropped down to make the ramps level
Tassie f100 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2020, 01:35 PM   #9
Silver Ghia
Silver Ghia's Avatar
I don't think much of that design (first video), without diagonal bracing to prevent them from collapsing sideways.
Silver Ghia is online now   Reply With Quote Multi-Quote with this Post
Old 05-10-2020, 06:27 PM   #10
GCRXR6
GCRXR6's Avatar
My thoughts as well. He did respond to a like comment, that he did rectify this later.
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better!
GCRXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-10-2020, 08:32 PM   #11
Pis-ton broke
didn,t every thing brake at over double "rated working load" if so , then that's great. if not, then i would be concerned that chinese stuff isn,t up to spec and is dangerous. it shows that the australian standards are being administered . and if you chose to work under overloaded gear, then your an idiot and this is party how accidents happen.
if you want high load rating, just buy higher rated gear.
Old 05-10-2020, 08:40 PM   #12
Tassie f100
Without going back over the video I’m pretty sure most of the stands were breaking at 4-5 times rated load.Jack stands don’t collapse under a stable load.Most “accidents” occur when the car gets moved and the stands fall rather than failing.
Old 05-10-2020, 09:31 PM   #13
Pis-ton broke
agreed, some people don,t know how to set a safe working area under a car. as a general rule i follow is; set up stands on grass, well i will throw large blocks of wood or car rims with tyres under the chassis rails. if the stands fail or move i have a redundancy safety backup.
Old 06-10-2020, 01:46 PM   #14
XD 351 Ute
Excessive Fuel Ingestion
XD 351 Ute's Avatar
Old mate and his press channel is an absolute crackup. The things he squashes are unreal!
Ed
Recommended Forum Traders: RSGerry, trimmaster, 51OAU, EB-92, adxr8, my67xr, RG, ZA-289, kruptor, gassa, Felony, RNXR, Rhino 351, Anchor, Smoke Pursuit, Mr. FPV (through E-Bay),
XD 351 Ute is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2020, 02:03 PM   #15
Vesper Martini
Vesper Martini's Avatar
From the videos I would say jack stands are very strong.. the amount of weight to break just one. when you normally spread the load over 2 or 4.
as above I'd be more concerned of the slipping or tipping over
Personally I use hardwood blocks.
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2020, 02:22 PM   #16
gutza
Hi Bevsta.
Totally agree. They all seemed to exceed their safety rating.
I was curious about the failure points.
The one that surprised me a little, was the trolley jack.
I was expecting the seals / o-rings on the piston to fail before the frame crumpled.
Old 06-10-2020, 02:36 PM   #17
Tassie f100
Hi Bevsta.
Yeah says a bit for the hydraulic seals.The old plain jane bottle jack collapsed at about 10 times limit didn’t it.wheras the floor jack frame was the weakest link
Old 06-10-2020, 02:49 PM   #18
gutza
Hi Tassie.
Spot on. Hydraulics are very powerful ....
Old 06-10-2020, 02:56 PM   #19
Vesper Martini
I've straightened up a house using a bottle jack, my biggest issue was stopping the jack sinking into the ground
Old 07-10-2020, 09:31 AM   #20
JGthirty3
Autobarn Stand recall.
https://drive.google.com/file/d/1Ea7...CmUB7N_oN/view
JGthirty3 is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2020, 03:26 PM   #21
gutza
Originally Posted by JGthirty3 View Post
Interesting. The first video showed, seemed to show the same failure point, although at a lot higher 'pressure'.
Old 08-10-2020, 04:00 PM   #22
roKWiz
Cabover nut
roKWiz's Avatar
Agree, Just this morning I was lifting 500Kg Granite blocks onto the truck with the hydraulic hand crane rated at 1000Kg @ the shortest reach. The weakness is what the crane is bolted to ie the trucks alloy tray.
Even with the attachment points through bolted with a steel packer and spread over several webs of the frame + a steel outriggers underneath, I could see the tray deflection.
heritagestonemason.com/Fordlouisvillerestoration
In order that the labour of centuries past may not be in vain during the centuries to come...... D. Diderot 1752
roKWiz is offline   Reply With Quote Multi-Quote with this Post
Old 08-10-2020, 11:25 PM   #23
Crazy Dazz
https://www.productsafety.gov.au/rec...-3000kg-4000kg
