Old 16-02-2018, 10:05 PM   #1
Earl Hickey
Default Is this a Ford part number au-2 1 3000arh/04/00
I m searching for a ds/large Tickford AU1 headlight protector..was told this is on the protector i m thinking about buying..can anyone help identify the part.
. au-2 1 3000arh/04/00
Earl Hickey is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2018, 09:58 AM   #2
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default Re: Is this a Ford part number au-2 1 3000arh/04/00
It is a Ford part number but not quite right.
AU2 13000 A HEADLAMP PROTECTORS, FITTING TOOL MUST BE USED, XR
They were about $102 last time we updated the parts DB but that was 5 years ago.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2018, 12:41 PM   #3
Earl Hickey
Any idea if it is AU1 or 2?
Old 18-02-2018, 12:43 PM   #4
russellw
russellw's Avatar
It is both - the use of AU2 in the numbering only indicates that it supercedes the previous part number. As there is also no AU3 part listed the AU2 part will also be suitable for those.
Regards
Russ
Old 18-02-2018, 05:25 PM   #5
Blue Dog
AU Falcon XR Headlight Protectors Part Number:
From 01/07/1998 to 29/02/2000 - ER 13000 B
Headlight Fitting Tool Part Number:
From 01/07/1998 to 29/02/2000 - ER 13T000 A
Blue Dog is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2018, 06:03 PM   #6
Earl Hickey
thanks for the replies.
Old 24-02-2018, 01:37 PM   #7
Dingo
Ford T3 Partsologist
Dingo's Avatar
Earl your Number AU2-13000-A (RH) is the RH Headlight Cover that fits AU XR8 Series 2 & 3 it was part of the kit AU2-13000-A you could only purchase them as a pair with the the fitting kit less the tool also this cover will not fit AU XR8 Series 1
The 04/00 means when it was made April 2000
i hope this info is of some help to you.
regards Dingo
2002 Blueprint T3 TE50 Manual Koni Suspension # 161
T-Series Club of Australia - www.tseriesclub.org
Dingo is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2018, 06:21 PM   #8
Earl Hickey
thanks for your reply.
