Old 02-12-2017, 09:59 AM   #1
GT0336
GT Pilot
GT0336's Avatar
Default Bolt on H shifter to Sequential Converter
Found this on car advice this morning. just bolts on and converts H shifter to sequential.
http://www.caradvice.com.au/599448/t...ntial-shifter/
2005 BA MK2 FPV GT 6 SPEED MANUAL.
LOWERED WITH BILSTEIN AND LOVELLS SPRINGS, CUSTOM QUAD EXHAUST, PACEMAKER HEADERS, 200 CPSI CATS, CAI, 80MM THROTTLE BODY, SHAKER, FACTORY SAT NAV, REVERSE CAMERA, CUSTOM ALPINE/DLS SOUND SYSTEM. CUSTOM GT-P LEATHER SEATS BY LEATHER-FX.
TUNED BY SPIRO AT AUTOTECH - 287.9 RWKW
Build Thread
2009 SY FPV F6X
2017 Mustang GT
GT0336 is offline   Reply With Quote Multi-Quote with this Post
Old 02-12-2017, 10:14 AM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Default Re: Bolt on H shifter to Sequential Converter
$3000 just to look cool!................pass.
Old 02-12-2017, 11:25 AM   #3
There are a couple of folks mounting sequential shifters on their transmissions over in The Workshop. Kind of pricey
We had a pure drag race G-Force "clutchless" transmission which used a Long vertical shifter. You would launch the car by putting the engine on the low side chip and dropping the clutch. Then you would not touch the clutch again as you rowed through the gears. It was a low inertia transmission and mixed with that shifter every other race transmission combination we tried was only within 5 hundredths of that transmission/shifter/clutch combination.
Back then the entire transmission and shifter were just a little over 5K usd. 3K for a shifter alone, wow. If you class race, I wonder if it will get through the gears quicker than a modern day Ronnie Sox?
