Old 13-11-2016, 11:33 AM   #1
OzriderXR8
OzriderXR8's Avatar
Default Loud Whistling sound on accelaration
Hi Guys
This noise is giving me the sh$ts.
Any ideas?
Cheers Ozrider
AUII XR8 200KW
FG MK2 XR6
Mini 850
Rover P5 3 Litre Mk1
OzriderXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2016, 01:16 PM   #2
Default Re: Loud Whistling sound on accelaration
Do you have the standard air ducting and if so is the donut (or it is black pudding sausage ) shaped duct (correctly called a "Helmholtz resonator") around/ above the passenger's side shock tower in place and properly attached? It stops standing wave vibrations from inducted air that both makes that sort of noise and interferes with the correct functioning of the MAF. Named after Helmholtz resonance or wind throb which is the phenomenon of air resonance in a cavity, such as when one blows across the top of an empty bottle.
Old 13-11-2016, 01:23 PM   #3
OzriderXR8
OzriderXR8's Avatar
Originally Posted by aussiblue View Post
Do you have the standard air ducting and if so is the donut shaped duct (correctly called a "Helmholtz resonator") around the shock tower in place? It stops standing wave vibrations from inducted air that both makes that sort of noise and interferes with the correct functioning of the MAF. Named after Helmholtz resonance or wind throb which is the phenomenon of air resonance in a cavity, such as when one blows across the top of an empty bottle.
First thing I tried, same on or off.
Cheers Ozrider
AUII XR8 200KW
FG MK2 XR6
Mini 850
Old 13-11-2016, 01:28 PM   #4
Still sounds like Helmholtz resonance; check the air filter is not inverted, no holes in ducting and the air box lid is on properly. Also check under front bumper that the plastic splash guard has not fallen down.
Old 13-11-2016, 03:18 PM   #5
OzriderXR8
OzriderXR8's Avatar
Pulled everything off the air intake, cleaned all the joins and reassembled with a bit of good old Vaseline. Sealed up all the joint around the snorkel and the airbox.
Test drive shortly.
I suspect it's the snorkel / airbox join, lots of gaps.
Cheers Ozrider
AUII XR8 200KW
FG MK2 XR6
Mini 850
Old 13-11-2016, 03:29 PM   #6
hales231271
hales231271's Avatar
I have had something very similar.
It was the heater valve tap.
The diaphragm was stuffed.
Never really noticed due to the fact never use hot control living in Queensland.
This is connected to the heater controls via the vacuum line , constantly " wistle sucking" noise as it could not form a vacuum due to the diaphragm.
It may not be the problem but worth a look.
Check to see if the valve moves when changing from hot to cold on the dial.
Dazza
AU XR8 Pursuit 250 , Monsoon Blue
AU XR8 Rebel , Monsoon Blue
hales231271 is offline   Reply With Quote Multi-Quote with this Post
Old 13-11-2016, 03:44 PM   #7
OzriderXR8
OzriderXR8's Avatar
Test drive shortly.
Cut it by about 70%, I think I'm on the right path.
Cheers Ozrider
AUII XR8 200KW
FG MK2 XR6
Mini 850
