Old 14-03-2015, 08:04 PM   #1
Bunky Twincam
Default New servo , brakes lock on
Hello all,
I have removed the troublesome MK2A Girling servo and installed a Lockheed.
As soon as I start the car without touching the brake pedal the brakes lock on.
When I take the cap off the white plastic breather ( under the letters "O" on the picture, it just pulls off and has a piece of plastic and a foam filter inside) and pull the little plunger up the brakes come off and I can roll the car.
If I disconnect the vacuum to the servo the brakes do not lock on.
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Bunky Twincam is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2015, 08:21 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: New servo , brakes lock on
make sure the non return valve in the Lockheed.system is working (called one way air valve )
could be that cap is to be left off after fitting the booster ..not sure on that myself
or the problem is in that black round disc called the air valve
used as an example only
http://www.triumph-spitfire.nl/servoimages.htm
My car goes Brumm Brumm
