Old 28-02-2015, 12:54 AM   #1
gnilrac
Default escort mk2 temp gauge shows overheating
Hi,there!Thanks for viewing my problem.I have a 1980 escort mk2,automatic transmission.My problem is the engine overheats fairly quickly,and not even strenuous driving.The waterpump appears to be moving the coolant as I can see it moving when the radiator cap is off.There is a small hole in top of radiator,about,1mm ontop.Can that little hole cause it to overheat so quickly?Any advice would be appreciated.
gnilrac is offline   Reply With Quote Multi-Quote with this Post
Old 28-02-2015, 05:26 AM   #2
dirty hands
Over Thinker
dirty hands's Avatar
Default Re: escort mk2 temp gauge shows overheating
yes a hole can
you cant have any air in a cooling system like that ..it is pressurised
have the radiator and cores checked
the thermostat must be open if water flows
and check the thermatic fans if fitted ....do kick in
My car goes Brumm Brumm
Old 28-02-2015, 06:06 AM   #3
gnilrac
Thanks 4 answer.I patched hole this morning,but noticed there's a oil smear from the head gasket,not major,so I suspect its broken there.Could that also be a cause?And when refuelling ,I can smell that the petrol somewhat fuming from the locked petrol cap!Its like the petrol is trying to leak out of the cap?What could that be,as I am dumbfounded with that one.There are no leaks ,fuel.oil or water visible wen I leave the car overnight with a clean cardboard underneath.Thanks again for advice.
