Old 22-07-2014, 07:58 AM   #1
boss351290
Default Help - Can you reco a TS50 headlight?
Hello all.
I want to put new front lights on a ts50 T3 as they have a lot of sandblasting on the plastic lens. I don't think you can buy new ones with the blacked out inserts. Can mine be rebuilt, or can I buy a new standard set of headlights and pull them apart and paint the inside surrounds black??
Any help would be appreciated. In Sydney area.
boss351290 is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2014, 08:44 AM   #2
buggo
[BU66OS]
buggo's Avatar
Default Re: Help - Can you reco a TS50 headlight?
Is it possible to take off the front plastic of a standard set than reseal it onto the TS backing?
FG XR6 Turbo Nitro
BA XR8 Manual
buggo is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2014, 09:07 AM   #3
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
I've done it with the Fairlane lights so I'd assume the falcon lights are the same. I used a heat gun to heat up the polyurethane sealant and paint craper to gently prise the lens and cover apart. Going back together is the same, heat the sealant up, add a little more to ensure a good seal then press the whole lot back together. Or, heat the seal, press it back together and then run a bead of silicone around the outer edge to ensure a good seal. There's nothing worse than condensation build up inside the light after a good rain.
MINE- AUII Forte
Old 22-07-2014, 09:35 AM   #4
byamin
byamin's Avatar
http://www.fordforums.com.au/showthr...ing+headlights
byamin is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2014, 09:13 PM   #5
Nikked
Oo\===/oO
Nikked's Avatar
You can take them out and sand back the lense, then polish them back up etc...
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 22-07-2014, 09:20 PM   #6
Matty4
Banana
Matty4's Avatar
Yep. If they're dull and yellowed, you can sand that off and then polish them back to clear.
Depending on how bad they are try using some 1500 wet and dry with plenty of soapy water, progressing to 2000 wet and dry. Then using a buffing machine with some fine cutting compound will have them looking great again. You can also look into re applying a UV coating to try and prevent them yellowing in the future.
2024 Ford Ranger Wildtrak V6 w/PP
2012 WK2 Jeep Grand Cherokee Overland CRD
Matty4 is offline   Reply With Quote Multi-Quote with this Post
Old 23-07-2014, 07:49 AM   #7
boss351290
Thanks everybody for your input. As always I can't believe how smart you guys are. thanks.
Old 23-07-2014, 09:32 AM   #8
xr6tjet
[AUT-747]
xr6tjet's Avatar
Yes you can just buy new headlights and paint the bezels in the colour of your choice OR swap over existing ones. Guide on here on how to do it goodluck!
xr6tjet is offline   Reply With Quote Multi-Quote with this Post
