Old 20-07-2014, 02:00 AM   #1
Crazy Dazz
Default Best way to judge Wear & Tear on a vehicle?
As a general rule lower kilometres are obviously desirable, so the odometer reading combined with the strength of the service & maintenance history is a good indicator.
But there are so many problems with modern electronic clusters, changing them out has become common, which makes me suspicious about some of the cars I have seen. Cars that claim to have moderate kilometres but have flogged out components.
In the days when cars "clocked" at 100k, my ole Dad always reckoned the tip was to look at the wear on the brake pedal, as that was something few people thought to replace.
What would you look at, if you thought the kilometres weren't legit?
Making Whine from the Tears of Hippies
Old 20-07-2014, 02:13 AM   #2
FormulaFG
Lurking......
FormulaFG's Avatar
Default Re: Best way to judge Wear & Tear on a vehicle?
Brake pedal is actually pretty clever idea.
Wear and tear on the drivers seat from constantly getting in and out over the years. Not much help if there were seat covers on I guess though.
The steering wheel, how smooth has it become? They leave the factory with little dimples and stuff in them but over time your hands smooth them out.
FormulaFG is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2014, 02:31 AM   #3
^^^^ as above, check for looseness in the indicator stalk, wear on ign key (if its original), carpets/mats,compare door handles with passenger and rear handles and my favourite to tell for neglect/lack of service- remove oil cap and scrape finger as deep as possible on the inside of the rocker cover. Clean oil and no deposits are a positive sign.
Hope that helps.
Old 20-07-2014, 05:57 AM   #4
2011G6E
2011G6E's Avatar
I agree...brake pedal rubber. Possibly also the carpet under the accelerator pedal...that used to be a good indication. General "looseness" of fittings is another good guide...however given the way some of the things in our G6E were fitted and just banged shut loosely (no "soft close" on things like passenger roof grab handles, etc) it's kind of hard to use that as a guide sometimes.
Basically, look anywhere that will be an obvious spot for wear over time...carpets, the side of the drivers seat where you slide in and out, indicator stalk, even printed lettering on buttons and things like that.
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2014, 08:35 AM   #5
The Yeti
The Yeti's Avatar
There's no 1 thing, it's a combination of all the above, how the doors close the ware on the floor mat all sorts of things.
To adjust a Denis Denuto quote
It's the "feel" of the thing
Pariahs C.C.
What could possibly go wrong
I post images with postimg.cc (so I don’t forget)
The Yeti is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2014, 08:40 AM   #6
pottery beige
pm hulk he knows the bizz
6 users like this post:
Old 20-07-2014, 09:27 AM   #7
Taily
Wear on door hinges (door dropping or flogged out checkstraps), indicator stalk loseness and a wear pattern beginning where it is touched to turn right/lanechange, carpet is a good one, brake pedal possibly (as some folks still cannot let go of left foot braking), those tiny (read millions) of chips in the windscreen (not the larger stone chips) will give you an idea maybe in what type of environment the car has operated (ie; how sandy/salty etc).
Different cars will wear differently more dependantly upon how they are used (ie; you wont cause wear to a car the same way I might) etc....
Failing that, as PB suggests, just ask Hulk. He's been there and done that on every car there ever was!
Taily is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2014, 05:06 PM   #8
Itsme
Experienced Member
Itsme's Avatar
What age of vehicle are we really talking about?
You compare it to other same models that you know are in VGC.
Itsme is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2014, 05:25 PM   #9
commonrails
commonrails's Avatar
Check out as many of the same make and model possible and you will soon work out who's who in the zoo.
commonrails is offline   Reply With Quote Multi-Quote with this Post
Old 20-07-2014, 05:26 PM   #10
Crazy Dazz
That's the thing, the car is over a decade old, it looks and feels to be in "reasonable condition for its age," albeit slightly more worn in places than the average I have looked at. BUT showing under 100kk. Conceptually not implausible, but yeah doesn't gel with the feel of the car.
Old 20-07-2014, 06:22 PM   #11
ebxr8240
Performance moderator
ebxr8240's Avatar
Don't believe klmrs on any Jap import !!
Daily driver GTE FG..
Old 21-07-2014, 01:48 AM   #12
T-Pak Addict
Jim
T-Pak Addict's Avatar
Its too hard these days to accurately judge based on kays sometimes but you have to take each car on its merit. Yeah sometimes it is just "the vibe of the thing". I have seen some 200k cars that are just pristine in every way and others that have just had such an uncared for life..... It comes down to the previous owner.
100k cars are just too hard to pick, by 200k they are dead easy to see whats been looked after and whats not... Years ago I had a friend I got into an argument with just on this very issue me telling him I would prefer a higher kay car (200k+) over a 100k car anyday. Here was my reasoning... by about 100-150k there are a lot of parts that start to give up the ghost as it were, shocks, bushes, waterpumps, hoses, niggling electrical issues etc ect by 200k most of these parts have been or should have been replaced. So you can tell with just one drive how good the car feels at 200,000 it will either drive like a pig or drive pretty dam good.
A few people that have driven my car can't believe how well mine drives (drives tighter than theirs) and mine has just been run in at 572,000 kays
The Daily. White 2017 ZG Escape TDCI AWD Wagon
The Wifes. Grey 2015 MD Mondeo TCDI Hatch
The Old Daily.......2003 Octane BA Taxi Pak Egas Falcon Build Thread
T-Pak Addict is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2014, 07:30 AM   #13
HULK_I6T
Apologies for the belated reply.
Communal/emergency vehicles: An obvious check would be to look at the service books for the original owner, if it's the police, a rental car company, govt or a taxi company then you know the car has been thrashed. Any sort of communal use, intermittent drivers etc. I'd just turn and run if the owners manual showed up these type of owners. But If your willing to take the car on despite the original owner (police, rental, govt, taxi) then make sure you buy it for a steal of a price to cover for the additional maintenance costs and costs to refreshen the car.
Company car: If a company car it could also have been thrashed but you might be lucky. Do your checks.
Private owner cars: The best car will always be a low km car and when you can speak to the original owner and person who was the driver of the car. Then you can ask pertinent questions and get a feel for the owners car care regime. Don't be adverse to pay a bit of a premium for a proper car, they will reward you with lower maintenance costs in the long term.
Poorly serviced cars: Also look for any cheap mods or non genuine parts added. It shows the owner tried to skimp on fixing the car properly (p platers etc) and may have tried to cheap out on servicing too. If a p plater was the regular driver of the car id run away also but this is just my own personal opinion. If your just unsure just stick to the km rule, the lower the better, assume all cars are abused, the car with less abuse (km) is likely better. If you don't trust the km go to the original owner rule.
It really is a jungle out there, best of luck.
HULK_I6T is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2014, 12:14 PM   #14
T-Pak Addict
Jim
how do you determine a car has been poorly serviced??
I do all my own servicing, replace all my own parts as needed... oh I don't have a rubber stamp in my book..... must be poorly serviced....
There is always an exception to the rule.....
What is a cheap mod??
I bought XR6 springs for my car for $50, actually I have a lot of cheap mods....
My car therefor is rubbish...
I don't know how I can live with myself for putting everyone at risk...
https://www.youtube.com/watch?v=gls09kO-8DE
Old 21-07-2014, 12:32 PM   #15
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Or any E series or AU, in an AU you can just swap over the cluster lol.
Franco Cozzo is online now   Reply With Quote Multi-Quote with this Post
Old 21-07-2014, 01:30 PM   #16
T-Pak Addict
Jim
Well pretty much any car with the right tools and equipment for that matter...
I changed the cluster (and got it modded) on my car, did the right thing and got the correct kays put back on it...
Don't think anyone would believe my car had 95k on it, so got it changed back to 530k which it had at the time....
My car wears its kays like a badge of honour...
6 years it suffered at the hands of crap drivers, many passengers and drunk people.... It now lives with me, gets treated with love, kindness, never wants for anything, its needs always met and it pays me back with getting me around to where ever I need to go... Every time....
Old 21-07-2014, 02:48 PM   #17
HULK_I6T
Old 21-07-2014, 02:55 PM   #18
T-Pak Addict
Jim
Your wisdom just shines in this thread Hulk.....
Old 21-07-2014, 03:04 PM   #19
BradEL
BradEL's Avatar
Look at things like gear shifters, handbrakes, pedals, carpets, seats, armrests, door handles, hinges ect.
BradEL is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2014, 06:13 PM   #20
dogfish
dogfish's Avatar
Hey Hulk_I6T I don't mean to sound like a knob but I reckon they're taking the **** out of you, do you not realize????????
If not that is rather amusing,
If so that is more amusing as you answer so honestly and childlike as if a deer in the head lights sorry dude but the stuff you put up about used cars etc is pretty common place bud I don't think that many people here are going "Hey Bruzz I got a cool new Ex Filth car and it's got all the bells and whistles and I only paid 70 grand for it SWEEEEEEEEEET, never been over 100kph or revved harder than 3 grand".
But I suppose at least people remeber you even if they are taking the ****.
dogfish is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2014, 06:42 PM   #21
Jastel
Technical Contributor: For members who share their technical expertise. - Issue reason: Has much experience with taxis and always jumps on here to explain things simply and help out the new guys in B-series and Contemporary...
One of the best cop cars I ever had was driven by the Inspector of Police...but I knew that before I bought it.
One of the biggest lemons I had was an original one owner little old man private sale.
They are general rules but there are exceptions to all of them.
Modern cars are not able to abused as much, the electronics wont let them, they can still be driven into and over things by the driver but.
Jastel is offline   Reply With Quote Multi-Quote with this Post
Old 21-07-2014, 07:38 PM   #22
Road Games
Road Games's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Replacement.
I think the internet warriors should pull there heads in .. just sayin'
as you were...
Road Games is offline   Reply With Quote Multi-Quote with this Post
Old 24-07-2014, 05:31 PM   #23
dogfish
dogfish's Avatar
XR6menace if you're refering me as an internet warrior I'd be thinking you're wrong. I'm hardly ever on here for a start as it is so over policed and secondly poor ole Hulk answers sincerely when people are just geeing him up, I was merely asking if he detected the sarcasm in other peoples posts.
So I have no qualms if I ever met him or you for that matter to tell him exactly to his face what was written here.
A few of the other members that know me personally on here would vouch for that.
I'm not afraid to tell it how it is in actual real life even if it comes at a cost to me.
So as i said before if you're thinking I'm a keyboard warrior you'd be thinking WRONG.
Old 24-07-2014, 05:37 PM   #24
Franco Cozzo
Thailand Specials
Originally Posted by HULK_I6T View Post
Meh, buy my Focus, been washed less than 5 times in 3 years, had 60kg of cow **** in the back once and a lawn mower a few times and one of my toolboxes in and out daily.
Old 24-07-2014, 06:26 PM   #25
commonrails
Immaculate, one careful owner, log book history, as new condition and a credit to the previous owner!
Old 24-07-2014, 07:31 PM   #26
Itsme
Experienced Member
Itsme's Avatar
You would hope so being low km's but again I've seen some poorly maintained in bad condition, I've seen some higher km cars in superb condition which is a credit to some owners who look after them.
Old 25-07-2014, 12:04 AM   #27
DanielXR8
You forgot to add lady driver (surely the wife drove it at least once), non smoker, country car (you can smell the fresh country grass in the boot).
DanielXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2014, 12:11 AM   #28
Franco Cozzo
Thailand Specials
My missus steers
Thats the spirit!
Technically:
- full log book history
- One owner
2/5 - 40% a pass in todays Year 11/12 LOL.
Old 26-07-2014, 06:01 PM   #29
MercuryT
MercuryT's Avatar
For mine the drivers seat gives away true Ks gave away the Ks when compared to passenger.
Recently drove an imported R33 GTR with "80Ks" - seat was really worn (and other like pedals and gear knob) and when asked about history etc "it's in Japanese, I just went off Odometer". Haha.
MercuryT is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2014, 11:13 PM   #30
T-Pak Addict
Jim
I am the 2nd owner, previous owner had it serviced once a month, inspected every 12 months... So should be a good one...
