04-02-2014, 11:30 PM | #1 | ||
hi
someone has a eb s pack with a standard 4 litre engine with extractors that go half way down the engine such as these http://members.dodo.net.au/~cason2/lukey.jpg and a redback 2.5 inch exhaust with front and back mufflers such as this http://www.performanceexhaust.com.au...20HS1005_1.jpg but using the standard ford cat converter have a ef fairmont with a 4 litre engine with the exact above but a high flow cat and want to make it sound as deep as that eb does with the exact same extractors and exhaust the note on the eb is deeper than the ef with the same exhaust and extractors for some reason. the ef has had a xr6 ecu in and does go quite good with it would the cat converters have anything to do or what else could it be both eb and ef have the exact brand exhausts and extractors both models with front and back mufflers |
05-02-2014, 10:06 PM | #2 | ||
hoons cause global warmin
think you will find its the intake manifold making the difference
"if you believe you can, or believe you cant, your probably right" (henry ford) |
07-02-2014, 09:53 AM | #3 | ||
how do you get a ef to sound deeper but not loud even though it still sounds good or would a noisy power steering pump drown the exhaust sound a bit
08-02-2014, 02:20 AM | #4 | ||
muffler choice
09-02-2014, 01:06 AM | #5 | ||
redback rear and mid muffler 2.5 inch is what the eb has just that and 2.5 inch pipe and extractors and cat converter.
do high flow cat converters change exhaust sound do longer extractors change the exhaust sound from using shorter extractors what brand extractors are better pacemaker redback lukey some on ebay that look same as pacemaker longer ones that you can buy high flow cats that bolt straight on |
09-02-2014, 08:15 AM | #6 | ||
Berklee mufflers sound the best imho.
10-02-2014, 08:00 PM | #7 | ||
all these things affect sound. as does comp ratio, headwork. cam profile, mixture and timing, intake design, even spark plugs
10-02-2014, 08:07 PM | #8 | ||
DFDFDF
Take my advice guys... Dont waste your time with this guy's posts... He will just come back with some other stupid post.. And always lately its 'important'...
The Daily : 2012 Ford Territory The Restorer : 1994 Polynesian Green ED XR6 T5 - Completely stock, put away for a few years The Project : 1994 Velocity Blue ED Ford Futura - AU3 220kw XR8 5L V8 5-Speed in progress The Toys : 2003 GasGas EC250 & 2001 Yamaha DT230 |
11-02-2014, 07:51 PM | #9 | ||
EF XR6
To be honet man. I get the whole "i love that sound" but just make your car sound like it does. Make it sound unique. If all cars sound the same then it would be boring. Diffrent is good...diffrent stands out more
www.OzEcruisers.com.au
95 EF XR6: 5spd Manual, 3.45 LSD diff gears, JIM MOCK EXTRACTORS, 2 1/2" sports exhaust Short shifter, Pod filter in standard air box, 17 inch EL gt rims in gold. Lowered all round with king springs and pedders supsenion |
