29-01-2014, 04:43 PM | #1 | ||
Hi
1999 Falcon Forte Series 1 (Feb 1999) All of a sudden my two remotes (Black Smart Lock) , are SLOW to open my doors and boot. If i press the button for 10 seconds the doors or boot open. Any help would be appreciated, Thank's |
29-01-2014, 08:46 PM | #2 | ||
Next upgraded Mk1 Leopard
New Battery?
UK
29-01-2014, 08:54 PM | #3 | ||
Replaced remite battery, still nogood.
Reset both remotes using demister button and the reset instantly. So remote signal working. Pulled car bat and waited 10 mins remotes worked once straight away. Every thing else in car works ? |
30-01-2014, 12:33 PM | #4 | ||
Got up this morning and remote opened the door straight away, then did not work again for awhile.?
Replaced remote battery with new one, remote lights up but does not open door. Relearned remote ok and car accepted remote code straight away but still does not open door or boot without holding button in for a long time. Just pressed door open button and held in for 8 seconds and door locked but, did not open with remote, is their anything I can check?. |
30-01-2014, 11:44 PM | #5 | ||
CNC fixer guy
If so.eone else has a s1, then perhaps they could loan you a spare to learn and test? Or you could test on their car after it learns yours? That will help narrow things down.
But at the moment with 2 remotes doing it, sounds like the bcm?
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. |
31-01-2014, 05:44 AM | #6 | ||
Thank's mif73
It could be bcm, I had a fuse blow on the cig lighter socket the day before , (Cheap phone charger plug), do I have to replace it or can it be repaired or will a wreckers one do ?. |
31-01-2014, 12:50 PM | #7 | ||
Well remotes now work OK ! :-)
Eventually reloaded BCM (Initialized) i think,. Left ignition on for 61 minutes with no accessories going. Turned off for 1 minute. Now all is well both remotes open the boot and doors. I would say (assume) that the blown lighter fuse corrupted the BCM and it needed re initializing. Thanks for all your help it allowed me to narrow problem down. Don |
31-01-2014, 03:00 PM | #8 | ||
CNC fixer guy
Well done.
Beats buying a new bcm.
07-02-2014, 11:24 AM | #9 | ||
Oddly, mine did this too. Slow to open...So I opened them to replace the battery and there was no change. So I bought two new ones off ebay, and programmed them as well as the old two. The old two still slow as a wet week. The new pair fast as...Yes the ones I got from ebay might be 'cheap chinese knock offs', but they have the Ford logo, and look identiocal;, even in side. So for me, this worked out perfectly. Cheers
