fitted up a combination of whiteline and nolathane bushes 2-3 months ago.
they seemed good at the beginning, fair bit of road noise and a slightly harsh ride but quite responsive and the noise from what i suspect was a worn original bush had gone. fast forward to now and the front suspension has become super squeaky, quite annoying really. i'm thinking the only solutions are to turn up the radio or swap them out for rubber, which would be a bit of a waste as the bushes are brand new. what are ur experiences with nolthane/whiteline bushes? |
I have had a full set of nolathane bushes in my eb v8 for about 7 years now,apart from a harsher ride ive had absolutely no issues with them,did you grease the right parts of the bushes?
nolathane give an extremely harsh ride.
Do not squeak what so ever if greased correctly, need to be greased heavily ever 6 months most people say. And last a lot longer than rubber bushes. Whiteline bushes are similar to superpro and there my recommended bush to use or use original rubber. |
I gave mine a very thin smear of grease on installation years ago and they havent been touched since with no noises,so id have to disagree with regular greasing.
yeah greased the right parts. used all the supplied grease. some of it come out when putting them togeather but i dont think that could be avoided.
im not interested in pulling them out and regreasing them regularly, if i pull the control arms out they aren't going back in! ill put up with it for the time being and see how it goes. |
i like to be stroked
my 2007 ss had nolathane , worst bushes ever hard brittle and didnt last gone to a poly bush much better
A good friend will come and bail you out of jail...but a true friend will be sitting next to you saying "Damn...that was fun!" |
are your bolts all real tight on the control arms and tightened only with full weight on?
#8 | |||
i must admit i didn't do it at ride height, its pretty hard to get under there at ride height. ill use some ramps loosen and re-torque but i cant see that helping as for the first 6 weeks or more there was no noise at all. |
#9 | |||
This may fix your problem. |
#10 | |||
CNC fixer guy
I used Superpro bushes in the front end with plenty of the supplied grease everywhere and didnt have to worry about setting at ride height and it doesn't make a sound. Do Nolathane bushes twist like a stock rubber bush, or slide like Superpro etc? If they slide like the Superpro ones on the crush tube then he may not need to worry about tightening at ride height as the grease is for lubricating the urethane rubbing on the stationary crush tube like a bearing on a shaft. I do agree that rubber (or any bush that twists rather than slides) should be tightened at ride height though. Cheers.
Weekend Toy: S1 AU Fairlane V8 with LTD bits, Tickford 17" wheels, front and rear chin spoilers, series 2 front brake conversion with Super pro bushes, Pacemaker headers, rear muffler removed, Kings/Pedders lowered suspension, Koni adj rears, painted headlight bezels, HR 2300kg hitch, 2 stage shift kit, trans cooler, reverse cam and media player. Wife unit's : 2010 update FG XR6, reverse cam, HR 2300kg Hitch, German Maestro speakers, parcel shelf sub, trimmed mudflaps, batman stickers. Last edited by mif73; 07-01-2014 at 04:51 PM. |
they're like the superpro bushes. they made no noise for the first 2 months. don't think its got to do with not tightening at ride height.
#12 | ||
Missing a sock...
![]() ![]() Join Date: Mar 2012
I had the same problem in the XF, used nolathane, greased them and torqued to spec at ride height. Eventually got a squeak in the front end I couldn't trace that went away when driving in the wet.
A chap put me onto Lanotec, it's a lanolin based lubricant. I filled a 500ml trigger spray bottle, adjusted the nozzle to jet and squirted sparingly in and around the bushes - problem went away after a couple of days. Cost was around $22/litre from Repco. Cheers!
Real friends + great times = sheer bliss! Considering becoming an organ donor? Click here QLD Events, Cruises and Get Togethers: Click here Gain success instantly - lower your standards. It's not government funded - it's taxpayer funded.
