Old 19-08-2013, 09:57 AM   #1
james22
With da Warlords
james22's Avatar
Default XR8 wont crank?
Hi All.
Went out to the shed to wash my car yesterday and it wouldn't start.
The battery was preety flat, so I connected my jumper pack and kicked it over.
Too start with it would wind over and then just click from the solenoid like it does when flat. So I charged the battery and the jumper pack and tried again.
The second time, the car wouldn't even crank or click. So I cleaned the terminals and swapped the battery.
Now with a fresh battery & jumpstarter it refuses to even wind over... No clicking even. Voltage and everything is fine?
I'm wondering if the starter motor is gone? Or maybe solenoid?
The smartshield light isnt flashing when I attempt to start so I don't think its immobilised.
Any ideas? Maybe a good whack to the starter lol
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
Old 19-08-2013, 10:29 AM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: XR8 wont crank?
inhibitor switch if it's an auto try jiggling the tbar sometimes it is just a bit of of adjustment rather than faulty
[SIGPIC][/SIGPIC]
Rides:
Old 19-08-2013, 11:01 AM   #3
james22
With da Warlords
james22's Avatar
Unfortunately its a manual, so that rules it out... But its exactly the same symptom
Windsor Warlords
AU III XR-8220
Old 19-08-2013, 02:08 PM   #4
james22
With da Warlords
james22's Avatar
So after ringing infernosr and doing a little troubleshooting it might be the immobiliser after all.
When I turn the ignition to ON, The smartshield light stays lit up... Usually its meant to illuminate for a few seconds then turn off... So perhaps there's the problem?
Windsor Warlords
AU III XR-8220
Old 19-08-2013, 02:41 PM   #5
b2tf
not here much anymore
b2tf's Avatar
is the interior light blown?
2024 F150 XLT
Old 19-08-2013, 03:28 PM   #6
james22
With da Warlords
james22's Avatar
Yep tilt tray up too ford... Smartshield was active. Recoded key to BEM, and away it goes.
Windsor Warlords
AU III XR-8220
