Old 11-06-2013, 08:02 PM   #1
burkie_21
wild xr8
burkie_21's Avatar
Default auto to manual and diff gears
I have just bought a wrecked xh 5l 5 speed and am wondering if everything will swap ok into el sedan? Is the pedal box and tail shaft the same? I already have 4.11 diff gears ready to go in but are they to short for the manual?
Burkie
burkie_21 is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2013, 11:48 PM   #2
Sorted
OzEcruisers PRESIDENT
Sorted's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: For all the contributions you make to the AFF community.
Default Re: auto to manual and diff gears
4.11's and 5th gear will see you around 2600rpm at 100klms on the highway I think
I will double check and get back to you
Unsure about pedal box but do you really want to remove the entire dash to fit it? Just buy a mal wood clutch pin.
Look it up
Mal wood clutch pin also strengthens the clutch pedal better than a stock pedal box
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan
PROEF 13.46 @ 105.78mph
Tuned by DYNOMOTIVE
200BUX - AFF Drag Nats 2019 EF Wagon
Common knowledge that the more weight you take out of the car the less power you need to run the time.
Sorted is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2013, 08:37 AM   #3
burkie_21
wild xr8
burkie_21's Avatar
so that would mean no need to strengthen fire wall?
Old 12-06-2013, 08:41 AM   #4
AU Mont
4.11 + eseries T5 = way too short.
AU Mont is offline   Reply With Quote Multi-Quote with this Post
Old 12-06-2013, 10:27 AM   #5
Sorted
Sorted's Avatar
Yes you should strengthen the fire wall or you can wait until it tears open - it may or may not do this lol
The standard clutch pedal box assembly is weak in its standard from - the mal wood pin kit strengthens it or you could weld a bit of metal to strengthen it like I did
What happens to a pedal box with any sort of heavy clutch
Add a big chunk of metal so it doesn't bend/flex again
Where your dash ends up if you want to fix or change the pedal box
Tuned by DYNOMOTIVE
Old 12-06-2013, 02:14 PM   #6
burkie_21
wild xr8
burkie_21's Avatar
Not worried bout dash out. Easiest job on an e series. Might just pull it out to strengthen it.
What would be better gear set? 3.7s?
Old 12-06-2013, 02:22 PM   #7
AU Mont
whats the ratios with the XR8 gearboxes? I only know the 6cyl ones & can only give advice to suit them from my experience
Old 12-06-2013, 02:40 PM   #8
Sorted
Sorted's Avatar
Gear Ratios here http://www.trueblueford.com/EL_Gear_Ratios.html
Tuned by DYNOMOTIVE
Old 13-06-2013, 07:23 PM   #9
burkie_21
wild xr8
burkie_21's Avatar
going to order the mal wood pin adaptor instead but strengthin the manual box and replace when auto one fails. was looking on there site and they have short throw shifters for about 275, any one used these? seem to be cheaper than the rip shifters
Old 13-06-2013, 08:13 PM   #10
Sorted
Sorted's Avatar
Unsure what the Mal Wood one is like but I purchased a MGW T5 short shifter with 5 speed knob for a Mustang off MGW
Here is a pic of it fitted with the std gear boot fitted - I have upgraded to a custom black leather gear boot off ebay but don't have a pic
Tuned by DYNOMOTIVE
Old 13-06-2013, 08:28 PM   #11
AU Mont
Originally Posted by Sorted View Post
thanks
yep, 3.9's would be as far as you would go, it would be very snappy around town, and the V8 has a taller 1st gear than the 6 which doesnt make such a short diff ratio as bad
but still a big no to the 4.11's, it would be borderline annoying.
