24-03-2013, 09:44 PM | #1 | ||
When the daughter started our AU wagon today I noticed the valve gear sounded unusually noisy. Upon checking the oil level the dip stick was dry. After checking the filter and sump plug and noticing a very oily under side I put some oil in and started the motor, while it was idling I searched for a leak. I noticed oil dripping quite quickly from the oil light switch. Do these switches leak? Is it a Ford only part? Has anyone had to replace one? What tools will I need socket sze etc etc.
24-03-2013, 09:49 PM | #2 | ||
common problem $11.95 at supercheap http://www.supercheapauto.com.au/onl...d=128770#Cross
[SIGPIC][/SIGPIC]
26-03-2013, 07:24 PM | #4 | ||
Thanks for your help I purchased a new switch from autobarn and the oil leak was fixed in under an hour.
Even with the CAI removed access is tight, just took my time and kept my patcients. |
