Old 17-03-2013, 02:32 PM   #1
davemass11
Default Rear Seat Belts AU2
Hey Guys, Does anyone have any tips on how to access inertia reels for the rear seat belts on AU2 sedan?
Any help appreciated.
BlackXR8
davemass11 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2013, 05:18 PM   #2
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Default Re: Rear Seat Belts AU2
from memory you just pull the big fascia panel off and it's under there?
Old 17-03-2013, 05:41 PM   #3
BHDOGS
Yeh mate above the parcel shelf on the left and right is big white plastic sheets clipped in take them off carefully and there in there the middle seatbelt reel is under the parcel shelf itself just take out the clips and pull it backward towards the dash easy as
Old 17-03-2013, 05:42 PM   #4
BHDOGS
Also you'll need a six star Allen key or drill bit to undo the bolts
Old 17-03-2013, 07:07 PM   #5
davemass11
It's the outside pair I'm having trouble with. Are they in behind the panel adjacent to the rear window?
BlackXR8
Old 20-03-2013, 11:28 AM   #6
whiskers
gone fishing
whiskers's Avatar
you can also unclip the part where the belt comes through and you can also take that big plastic thing off and your belts are under that the bolts for the belt retractor are on the bottom of the retractor and the bolt for the belt to the car is sort of beside the back seat you can gain access to this bolt by taking the side bolsters out screw for that is at the bottom and then just push u. then the bolt for the seat belt is down the bottom of the seat I pop my seat out to get better access by pulling it up from the bottom.
hope this helps you.
I will be replacing mine soon and will post some pics if you want.
cheers
Whiskers
whiskers is offline   Reply With Quote Multi-Quote with this Post
Old 23-03-2013, 03:53 PM   #7
davemass11
Thanks Whiskers, I'll give it a go.
Let you know how I went.
BlackXR8
Old 09-08-2013, 09:54 PM   #8
DaveTE
Back in black
DaveTE's Avatar
Arrrh! I got 2nd hand rear seatbelts to replace mine in the XR8 which are shot(Spring coils gone). On removal these new ones were fine. Now the two side ones are stuck locked. I can see the coiled springs is fine but they are locked tight and wont let any belt out. How do I reset them to let the belt out?
Black Mac TE50 S3 NO: 106
Little Mac AU S2 XR8
Bite the snake before it bites you!
______________
_.__ /________...\
_.._(___\\___//___)
.._..(O...\____/...O)
DaveTE is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2022, 08:57 PM   #9
bondy99
cheers
Whiskers,
How did you go mate. I got the same problem.
bondy99 is offline   Reply With Quote Multi-Quote with this Post
Old 30-09-2022, 09:19 PM   #10
GasoLane
Former BTIKD
GasoLane's Avatar
Originally Posted by bondy99 View Post
Whiskers,
You do realise that Whiskers hasn't been online since 2014?
