Old 23-02-2013, 12:33 PM   #1
peterljohnson55
peterljohnson55's Avatar
Default New engine technology to replace camshafts? Check out this video.
The Future of the Internal Combustion Engine - Inside Koenigsegg
Inside Koenigsegg provides for the first time, a look behind the scenes at Koenigsegg and examine how innovation within the highest echelon of sports car manufacturers will affect the broader automotive world.
http://www.youtube.com/watch?v=Bch5B...&feature=share
-- Ford Fairmont Ghia AU2, 3/2001, Tickford 4.0 I6, 12v SOHC VCT MPFI, sedan with IRS standard suspension --
----- ANJ is a practical beast, but still a lady, that I want to keep alive until at least2021 -----
-------- Preventative Maintenance Policy --------
peterljohnson55 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 02:10 PM   #2
Jack960
Jack960's Avatar
Default Re: New engine technology to replace camshafts? Check out this video.
that would be incredible. Could get an engine moving much faster without the timing belt/chain cam shaft restrictions. Wouldn't mind seeing a xr6t at 10000+ rpm!
Jack960 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 02:26 PM   #3
Uncle Niceguy
more like 20000rpm Jack. it would make any modern engine look like something from the middle-ages
Uncle Niceguy is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 02:42 PM   #4
Sox
RIP...
Sox's Avatar
An XR6T engine wouldn't rev any better at all, as the primary limiting factor in those is the undersquare bore/stroke ratio.
Oval Everywhere...
Old 23-02-2013, 02:54 PM   #5
mik
mik's Avatar
would`nt be a bad thing to reduce the external dimensions on motors as well.
Old 23-02-2013, 03:19 PM   #6
cheap
Wirlankarra yanama
cheap's Avatar
Not sure if you'd call it new, using actuators/solenoids/compressed air and even magnets have been attempted a few times before.
For example, Renault developed a pneumatic valve system (no camshaft) for their F1 engines in the late 1980's. The Renault system has proven so good that every F1 engine now uses pneumatic valves.
Will be interesting to see if the Cargines technology can make it to mainstream use.
cheap is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 03:36 PM   #7
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Last year in Melbourne there was an expo of sorts (something to do with soccer) and there was a bunch of technical displays, one of which was an engine that functioned in a very different way to what is normal. Looked like a cross between a few different engines.
Took a video of it, will try and find it and post when I get home.
___________________________
Old 23-02-2013, 03:47 PM   #8
Moby Vic
Cynical Idealist
Moby Vic's Avatar
Funny, I had the idea of solenoid-controlled valves way back in the '90s for reducing engine friction, but of course not a clue as to how to implement it.
Your plastic pal who's fun to be with!
Moby Vic is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 03:59 PM   #9
ivorya
Mad Scientist!
ivorya's Avatar
Don't they use or have used a similar system in F1??
ivorya is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 04:24 PM   #10
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
F1 still has camshafts but has pneumatic valves instead of metal. MotoGP started using them too with the 800's.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 04:25 PM   #11
ryeman
Question Re: New engine technology to replace camshafts? Check out this video.
Weren't BMW using solenoids to activate their valves incl variable lift to control power ie ...small lift for idle, increasing for power.....forgotten what they called it...
VALVETRONIC?
Wherenoshockjocksfly
Facts or the twitterverse, your choice!
M3SR+ .......MG ZS EV
ryeman is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 04:41 PM   #12
f1tzy
f1tzy's Avatar
I believe they do still use camshafts but they use air actuated valve springs (ie no actual spring)
f1tzy is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 06:17 PM   #13
Angeldust
Angeldust's Avatar
VALVETRONIC?
VANOS i think its called.
Z series Clubsport HRT edition..
e46 320ci 2.2ltr Stocko
Angeldust is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 07:50 PM   #14
VANOS is BMW's version of VVT / VCT
VALVETRONIC replaced the throttle body and programed the opening of the valves and direct injection to simulate a throttle.
DFB FGXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 09:39 PM   #15
Jaxon
Great vid, thanks for posting. I remember seeing a documentary on that company years ago & was very impressed with what they were doing back then. Hope they keep it up.
Jaxon is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 10:17 PM   #16
kempy311
BEN
kempy311's Avatar
Awesome vid its amazing what technology is around.
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 10:38 PM   #17
turbodewd
FG Falcon fan
turbodewd's Avatar
Who needs hybrids?! Petrol n pistons has a while to go it seems...
turbodewd is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2013, 12:30 AM   #18
Night
I remember a F1 race in adelaide ages ago when Rubens drove for Jordan and he had to keep pitting to top up air for the pneumatic valves so something like this has been around for a while. What I find interesting is how he mentioned using an air tank to spool up some turbos or even driving the engine as an air engine for take off. This kind of technology could see some pretty hefty HP in future road car engines.
Night is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2013, 11:37 PM   #19
Djrystofer
Djrystofer's Avatar
Koenigsegg have always been extremely innovative
Love the idea, can't wait to see it put into production into little hatches and see the insane fuel economy/emissions benchmarks.
Can't see it being as reliable though.
Djrystofer is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2013, 07:33 AM   #20
mash again
have been discussing actuated valves with a mate for 10 years and no dought the car industry has been for much longer, but getting anything to survive in that environment long enough to be call reliable is probably the biggest hurdle, but infinate "cam" profiles changing with revs etc. or for economy and power would make for interesting tuning capabilities and no dought headaches.
OK i watched the video, Im sold where do i sign.
mash again is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2013, 05:03 PM   #21
XR_6falcon
awesome stuff! good too see people still pushing the boundries with combustion engines
Big dreams, not enough money
Smoke tyres, not drugs
XR_6falcon is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2013, 06:07 PM   #22
Nikked
Oo\===/oO
Nikked's Avatar
And poeple think OHC is modern...
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 25-02-2013, 08:19 PM   #23
Bossxr8
Peter Car
Bossxr8's Avatar
To GM, OHC is super futuristic.
Old 25-02-2013, 10:18 PM   #24
music189
great link
bloody hell I just lost 1/2 hour looking at all the other stuff
music189 is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2013, 01:42 PM   #25
Buntz
Straight Eight
Buntz's Avatar
Compressed air over electricity. Sounds like a winner to me.
No camshafts would be awesome. Think of the power to size ration engines could then achieve.
The Falcon is dead. Long live the Mighty Falcon.
Buntz is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2013, 02:11 PM   #26
2011G6E
2011G6E's Avatar
One thing that can't be overcome is piston speed...there's an upper limit to how far you can push that. It's usually overcome somewhat by having short stroke motors pushed to ridiculously high RPMs, but you still come up against a physical wall as to how fast you can make something move upwards, stop, then move back down again and repeat the process, no matter what exotic metals and materials are used inside the engine.
The figure is around 26 meters per second...I think 28mps is the theoretical maximum, and surprisingly this figure has been known since the very early days of the internal combustion engine. The highest street engine was in the Honda S2000 (25mps) and some drag cars apparently run up over 26 to 27, but that's about the mechanical limits.
2011G6E is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2013, 02:40 PM   #27
madmelon
Just to Clarify, VALVETRONIC uses an electric stepper motor to alter the length of a lever on which the cam operates, thus altering the valve opening height. It doesn't alter duration. VANOS is the BMW word for cam phasing.
madmelon is offline   Reply With Quote Multi-Quote with this Post
