Old 17-12-2012, 05:00 PM   #1
mrfalcoon
Default 5 sided torx
where do you buy a 5 sided torx bit from to remove the horn pad?
cant get one anywhere grrrr
mrfalcoon is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2012, 05:59 PM   #2
05_ENFORCER
05_ENFORCER's Avatar
Default Re: 5 sided torx
Bunnings or Stupidcheap Autos
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2012, 06:04 PM   #3
mrfalcoon
noooo there 6 sided
Old 17-12-2012, 06:07 PM   #4
Kryton
Kryton's Avatar
Bursons have a little 5 or 6 piece 5 sided Torx bit set for $20.
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2012, 06:13 PM   #5
KR1STO
Just another mock-up..
KR1STO's Avatar
Ford have a similar one (5 or 6 piece) for $16.. IIRC
I got mine from ford...
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2012, 06:16 PM   #6
mrfalcoon
so you think my local ford spare dealer should have this for $16 ? sounds to cheap from ford :-p
yay,i hope so.....
Old 17-12-2012, 06:16 PM   #7
Kryton
Kryton's Avatar
Ford have something for $16?
I've seen bolts cost more.
Old 17-12-2012, 06:24 PM   #8
nat75
ebay is your friend. type in 5 pin torx or the like. fairly cheap and works great. i couldnt find a single one elsewere
nat75 is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2012, 06:25 PM   #9
b2tf
not here much anymore
b2tf's Avatar
Ive got one. Got it off Ebay. If you cant find one let me know and I'll post mine to you so you can borrow it.
2024 F150 XLT
Old 17-12-2012, 06:27 PM   #10
05_ENFORCER
RyTool did a 10 piece set a while ago from Autobarn IIRC
Old 17-12-2012, 06:58 PM   #11
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Here it is. Central Tool Supplies is where I got mine from.
http://www.ebay.com.au/itm/5-POINT-T...item460b28080c
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2012, 07:01 PM   #12
mik
mik's Avatar
I could`nt get an appropriate torx without paying a small fortune and having to order one, so i got the little dremel out with little cutting wheel and carefully put screw driver slots on the heads , then replaced them with bolts or cap screws, i forget which, but did the job anyway.
Old 17-12-2012, 09:13 PM   #13
tim_pato
tim_pato's Avatar
got mine from the snap on truck for $30
au2 dedicated lpg tonner, just want a wee bit more stab.
wanted TS/TL50 front seats any condition pm me
tim_pato is offline   Reply With Quote Multi-Quote with this Post
Old 18-12-2012, 12:28 AM   #14
BHDOGS
got mine from autopro in adelaide
Old 24-12-2012, 12:29 PM   #15
Evgeni
Auto Nerd
Evgeni's Avatar
Having a look at some catalogues
Kincrome is now selling these torx bits as well.
http://www.kincrome.com.au/web/media...p?ss=1&AID=577
Old 24-12-2012, 07:37 PM   #16
irdonn
irdonn's Avatar
Where are you located mate? I've got one you can borrow if you're on the west side..
Ian
06/01 AUII XR8
irdonn is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2012, 09:55 PM   #17
Kryton
Kryton's Avatar
That is the exact kit i was talking about in my last post.
Old 24-12-2012, 10:29 PM   #18
Barnaby
Barnaby's Avatar
Just for everyone's information, there is a Torx standard, with tamper-proof (just the addition of the centre pin). Then there is a new standard called Torx-plus (Torx TX). If you are wondering why you old Torx drivers don't fit perfectly in a newer Torx fastener, its probably a because the fastener is Torx-plus. The Tamper-proof version of Torx-plus has 5 shoulders/pins.
Torx-plus was developed to to improve torque transfer to the fastener.
Barnaby is offline   Reply With Quote Multi-Quote with this Post
Old 24-12-2012, 10:49 PM   #19
BigCav
OzFalcon.com.au
BigCav's Avatar
5 sided is called tork ts
BigCav is offline   Reply With Quote Multi-Quote with this Post
