Old 14-11-2012, 02:10 PM   #1
xtraktor
fte or fpv, mmmm....
Default AU IRS control arm Bushes
My outer control arm bushes are flogged out on the top and bottom IRS control arms in my car.
Only the bottom of these bushes are available from Ford and Nolathane, where can I get the top bush? can I just use a bottom control arm bush in the top?
Has anyone changed these themselves?
Thanks
Mark
xtraktor is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2012, 03:34 PM   #2
BOTTLEDUP
Default Re: AU IRS control arm Bushes
They aren't a bush as such, but a spherical joint. You need a press to remove and install the new units. Top and bottom are different, there is no aftermarket available for the top joint and the Ford unit is now obsolete. The only solution I have found is to use a BA-BF one, but it is narrower and you'll need a spacer washer at either end of the joint.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2012, 03:44 PM   #3
BillC
You can also buy a tool off e bay to remove and replace the top bush $30 + postage. The tool is for a BA but as was previousely said the bush that replaces the AU one is now the BA one. It should work fine. I have bought it but have yet to try it. The bush in mine is not flogged out its just squeeky
BillC is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2012, 04:12 PM   #4
xtraktor
Thanks! have you got a link to the tool?
Old 14-11-2012, 06:18 PM   #5
MrEL
Sick Puppy
MrEL's Avatar
Im interested in a link to the tool myself.
MrEL is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2012, 06:26 PM   #6
BillC
here tis
http://www.ebay.com.au/itm/Ford-BA-R...item27ccc96be2
Old 30-12-2012, 01:06 AM   #7
BillC
Tried the tool today. The bush is in that tight it didnt budge a mm. I ended up stripping the bolt on the tool. I am going to try again tomorrow this time with a little heat. I dont think its the tools fault that it stripped. I may have been a little heavy handed.
Old 31-12-2012, 02:08 PM   #8
AUFanboy
FWIW Superpro bushes for AU IRS are now available, saw these the other day while browsing ebay
http://www.ebay.com.au/itm/Falcon-Fa...item460ae368af
AUFanboy is offline   Reply With Quote Multi-Quote with this Post
Old 07-01-2013, 12:20 AM   #9
BillC
Tried again today. The bush didnt budge at all. Tried heating it and hitting with a hammer but no movement at all. Looks like a trip to pedders. I think the tool I got from ebay was a good idea but in my case the whole arm will need to come out and placed on a 12 ton press.
Old 06-08-2019, 10:39 PM   #10
TickfordTiger
These bushes look the goods, set of 4 upper and lower :
https://www.ebay.com.au/itm/Ford-AU-...-/113763233821
T1 TL50 Build No. 014 - Liquid Silver
T1 TL50 Build No. 017 - Liquid Silver, Sunroof
TickfordTiger is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2020, 10:58 PM   #11
TickfordTiger
This link works, the other one has expired.
Many units sold and positive feedback.
Plus lots of information in the description.
https://www.ebay.com.au/itm/Ford-AU-...-/114345581207
