Old 03-11-2012, 11:23 AM   #1
SSD-85
Default Power window issue
Morning all,
Ive had a rather frustrating experience which started yesterday. My Fairmonts front passenger window wouldnt come back up.
Firstly, I sourced a replacment and it went down, but not back up. Now its an odd coincidence that both did it, so I checked the switch on another window & it worked fine so that rules that out. Also the drivers master doesnt work for it either.
Is there something else to look for or am I just unlucky & need yet another replacement?
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 03-11-2012, 11:29 AM   #2
Whoosha
AU DIE HARD
Whoosha's Avatar
Default Re: Power window issue
You need to do a complete pull apart and clean on both the master and the the door switch 99% of the time that will fix it it, easy done just do a search on window switch
Originally Posted by Riksta
Old 03-11-2012, 11:30 AM   #3
SSD-85
The thing is though, is the switch i pulled off the passenger front worked in the passenger rear. But it wont work in the front. So it cant be the switch.
Old 03-11-2012, 11:33 AM   #4
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Try here,
http://www.aufalcon.com.au/cgi-bin/i...=tutorials&i=2
Old 03-11-2012, 11:38 AM   #5
SSD-85
Ok, Ive just had the replacement tested, and it exhibited the same issue as mine.
However yet another unit was tested & it worked perfect so Ill install that one & see.
Sounds like I just was unlucky.
Old 03-11-2012, 02:52 PM   #6
Whoosha
AU DIE HARD
Whoosha's Avatar
They are a dodgey thing at best. give them all a good clean first you will see the contacts when you pull them apart if there to far gone you may have to replace them
Old 03-11-2012, 03:45 PM   #7
SSD-85
Ok, my car has made an idiot of me
Ive now learnt that the whole power window system hinges on the master switches working. Cleaned the damn master & it worked....
Im really sorry guys, I feel like such a noob. I shouldve known this.
Old 05-11-2012, 01:50 PM   #8
Dauphin
Irregular member
Dauphin's Avatar
Good to hear you sorted it out! I didn't know that either about the master switch, so we both learned something new!
