Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 26-10-2012, 11:44 PM   #1
Supersuit
Default relocating ABS module
Hi there Matt
Im going to relocate my ABS module and was wondering can I just empty out the brake system (drain all fluid) and move it to where I want and plumb it all back up or do I need to leave fluid in certain components??
Supersuit is offline   Reply With Quote Multi-Quote with this Post
Old 27-10-2012, 01:16 PM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: relocating ABS module
Originally Posted by Supersuit
Hi there Matt
Not really but you may find it will take a while to bleed it through and get a good pedal as the abs systems can be tricky when bleeding them once dry.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
Old 28-10-2012, 01:03 AM   #3
Supersuit
ok thanks mate, so it'll be fine to move around "dry" ??
Old 28-10-2012, 01:05 AM   #4
Supersuit
Also Can I blead the system with the engine off or dose it need to be running?? (was thinking of bleeding before doing the wiring)
Old 28-10-2012, 10:41 AM   #5
kempy311
BEN
kempy311's Avatar
Think you will find that you will need a scan tool to bleed it as I have found when changing other abs modules.
My Thread. The new whip: 2014 FGX XR8 Auto in victory gold. Mods : BMC air filter, 1500cc injectors, Walbro 485, 58mm kpm snout, kpm intercooler, 35% front and 20% rear tint, pedders supercar coilovers, whiteline sway bars, Phillips HIDs, lenso d1r wheels.
331rwkw.
12.7 sec stock as a rock with a passenger.
Now with 620rwhp ready to run the 10
built zf, built tailshaft, corn juice all to come.
The old rig: 2008 FG XR8 Auto in dash green with a tonne of mods to make 311rwkw.
kempy311 is offline   Reply With Quote Multi-Quote with this Post
Old 28-10-2012, 10:48 AM   #6
Supersuit
scan tool?? for what???
Old 28-10-2012, 10:49 AM   #7
kempy311
BEN
kempy311's Avatar
You will have to operate the valves in the abs module to bleed it.
331rwkw.
Old 29-10-2012, 01:27 PM   #8
FLOORED
Race Brakes Sydney
FLOORED's Avatar
I just spoke to a Ford technician and was told the only problem maybe resetting the brake warning switch once everything is re connected as the light should come on if it is disconnected.
Maybe contact Ford and speak to one of there mechanics and get a second opinion before you proceed.
PS. You may want to check the legality of moving the abs unit as well because this may also be a problem.
MATTHEW PEARCE
Phone 02 9609 1101
Old 31-10-2012, 10:45 AM   #9
Supersuit
Thanks guys I'll give ford a call if I run into trouble, I have a factory ford manual so that helps but I'm sure something will not go smoothly knowing my luck....
Old 31-10-2012, 11:31 AM   #10
FLOORED
Race Brakes Sydney
FLOORED's Avatar
No worries i was told this morning by another Ford mechanic who actually rang here about something that all late model Fords do need scanning/calibrating if they run dry.
MATTHEW PEARCE
Phone 02 9609 1101
