28-09-2012, 10:00 AM | #1 | ||
ROCKING THE EL FUTURA
im proud to announce that very soon i will be the owner of an 220kw rebel, i could not stand it anymore as great as the turbo is i just could not bond with that car at all and i missed my organza au. so i went and found a nice example rebel which im looking at tomoro.
the turbo is staying in the family my missus bought it of me so goodbuy hyundai. i will be part of the auvians once more and will never desert them again. your thoughts and what i should look out for ENGINE wise would be great.
BA MK11 XR8 ENFORCER NOW SADLY GONE My build that was http://www.fordforums.com.au/showthread.php?t=11267696 ENVI BA XR6T BUILD THREAD..http://www.fordforums.com.au/showthread.php?t=11345961 TAKEN BY THE EX NOW A EL FUTURA EB MONTY NOW IN THE SHED BACK IN THE E-SERIES THREAD DIGGEr |
28-09-2012, 10:58 AM | #2 | ||
5.6L x 2 pilot
Awesome. Welcome back. Hope the Rebel works out for you (if you end up buying it). Not aware of any significant items to look out for on the 220. Generally, I think you will find they are pretty bullet proof. I would of course be checking the obvious - the oil, oil leaks etc.
Good luck Stu
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
28-09-2012, 11:03 AM | #3 | ||
Critical Thinker
awesome pick up George. Well done. Where are the pics dammit???????
The 220kw versions are the hand built engine versions yes? As far as I am concerned these and the T-series are the V8's you want in the AU's. Hope you enjoy. That said, I am not surprised about the turbo. I have heard a lot of prodigal sons returning to the AU fold after spending rumspringer in a B series.
"Everybody was KungFu fighting..." 2022 Mazda CX5 GTSP Turbo 2024 Ford Everest Trend 1967 Ford XR FALCON 500 Cars previously owned: 2018 Hyundai Santa Fe Highlander 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
28-09-2012, 12:41 PM | #4 | ||
i had a chance to buy a pristine v8 au a while ago, i bought something else instead, kicking myself now, as above they are a pretty straight forward car, general wear and tear, oil leaks, servicing,etc, good luck with it.
28-09-2012, 01:05 PM | #5 | ||
lowfly
I still miss my AU-2 220, was a great car and I should have kept it.
My eldest boy now has my BA turbo and I was thinking maybe a T3 as a toy for the weekends. |
28-09-2012, 01:35 PM | #6 | |||
Back to Le Frenchy
Nice.
Check the au v8 thread for all the common issues. They do weep oil from where the dipstick enters the sump, the coil packs are a known issue, so are the rear upper shock mounts. Another thing to listen for are valve springs, the 220's break them. Apart from those cheap and easy items they're pretty bullet proof. That is unless you stroke them to a 347 and go a little nuts
28-09-2012, 05:07 PM | #7 | ||
pics will be up as soon as in driveway Shav now ill keep you waiting ahahahahaha...
thanks guys for the info i kinda gatherd that theese cars are great thats why im going back to them if the six can be as great as it was why shouldn't the hand built eights....
28-09-2012, 05:18 PM | #8 | |||
Next upgraded Mk1 Leopard
Welcome back to the dark side UK
28-09-2012, 07:53 PM | #9 | ||
Check for a clean cooling system/receipts for coolant changes. The timing cover can corrode out behind the water pump if muppets never change the coolant or run straight tap water, then you end up with a sump full of coolant. Pretty bulletproof if maintained though.
28-09-2012, 10:23 PM | #10 | |||
ok you can ban me but you wont see the new 220
29-09-2012, 08:56 AM | #11 | ||
Back in black
Radiator leaks down the plastic tanks on sides, Cam shaft sychroniser, thermostat switch and gasket, loose steering due to heat from extractors, window switches, shakes from harmonic balancer, windscreen leaks from old silicon, sagging roof lining and all of those mentioned.
Black Mac TE50 S3 NO: 106 Little Mac AU S2 XR8 Bite the snake before it bites you! ______________ _.__ /________...\ _.._(___\\___//___) .._..(O...\____/...O) |
29-09-2012, 09:43 AM | #12 | ||
Rob
there's just one problem you should be concerned about... the misses will have a faster car then you.. hmm i sense some mods ;)
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
29-09-2012, 11:29 AM | #13 | ||
Critical Thinker
But you cannot beat the raw sound of a V8. blow off valves, turbo's superchargers are all well and good, but you are just substituting the sound for the real thing......a V8
29-09-2012, 04:25 PM | #14 | ||
ok guys i lost my deposit on the au for this it was the missus's idea.
enjoy
29-09-2012, 04:26 PM | #15 | ||
two ENVIS in the stable all we need now is a normal xr6 and we are done lol
29-09-2012, 04:30 PM | #16 | ||
Afterburner + skids =
laaaame
29-09-2012, 04:33 PM | #17 | ||
^^^^^^^^ sorry you dont' like it ohhh well
29-09-2012, 04:34 PM | #18 | ||
5.6L x 2 pilot
Nah. Give me a Rebel any day of the week. 220kW@~1600kg or 260kW@>1800kg?
29-09-2012, 04:36 PM | #19 | |||
29-09-2012, 04:37 PM | #20 | ||
Giddy up.
Talk about a anticlimax, lol.
Seriously though mate, congrat's on the new ride. The AU would have been a better choice though, |
29-09-2012, 04:39 PM | #21 | |||
ohh yeh and when i got there it wasnt a rebel just a 200kw xr8 advertising was wrong aswell..
29-09-2012, 04:41 PM | #22 | |||
Yeah, sorry, that came across a bit rude. AU's are better, XR8 220's are better again! So, yeah, still lame, but congrats either way!
29-09-2012, 04:42 PM | #23 | ||
but if i do come across one i still will buy the damn thing dont car if i end up with no room in the yard i will buy one.....
29-09-2012, 04:44 PM | #24 | ||
this is the one but on the left side it was full of dents and scratches.
29-09-2012, 04:57 PM | #25 | |||
5.6L x 2 pilot
Good luck with your new ride. The driveway is certainly something you do not see every day. Enjoy your second green machine. Cheers Stu
29-09-2012, 04:58 PM | #26 | ||
so one car was 9k and the other 19k....... big price difference !!
29-09-2012, 05:01 PM | #27 | |||
yeh got it less than that but the missus bought the xr6 off me so now we need to sell a hyundai accent lol
29-09-2012, 05:02 PM | #28 | |||
5.6L x 2 pilot
Stu
29-09-2012, 05:08 PM | #29 | |||
29-09-2012, 05:08 PM | #30 | ||
Rebels never came out in Galaxy Blue, or any blue for that matter.
Shame he got the advert wrong, but yeah, clearly not a rebel or a 220kw from those pics. http://www.carsales.com.au/private/d...-2001-12754298
