Old 27-06-2012, 08:41 PM   #1
vesssh
Default Diff Question
My AUII XR8 ute has a slight whine coming from the diff. I have heard mixed thoughts from different people.
Some say to learn to deal with it as all Ford diffs whine, other have said to just change the diff oil. When going to the wreckers today to pick up my new rotors I asked him if changing the diff oil would make a difference, he said probably not. He reckons the diff could go at any time . . .
He suggested that when it comes time to get a new one that I should look at getting my diff built with EF gears as he said they are a lot stronger?? He said that the ratio will still stay at 3.45 and will obviously still be LSD.
Has anyone ever heard of this before?
Also, is a 3.45 ratio diff good for towing?
Cheers in advance
vesssh is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2012, 11:22 PM   #2
Gaz
Got Ghia?
Gaz's Avatar
Default Re: Diff Question
Step 1 - Ignore wrecker
Step 2 - Put in Castrol SAF-XA
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2012, 12:00 AM   #3
T2TICK4D
T2TICK4D's Avatar
i also have a wine coming from my au xr diff some have said mate its gone then some have said just service it
TE50 T2
AU2 GHIA
T2TICK4D is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2012, 12:34 AM   #4
mik
mik's Avatar
the statement all ford diffs whine is a load of crap mate, on occasion there has been the odd complaint in some models about backlash, whine is not normally a problem, mine has 200,000 hard k`s still going strong, no idea about the ef gears thing.
Old 28-06-2012, 08:32 AM   #5
vesssh
I will leave it for now. It whines a bit going forward, the whine increases when I reverse.
I will change the oil over the weekend and see how we go.
Old 28-06-2012, 03:07 PM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
nearly every time someone says that their diff whines they'll find that it's actually the BTR auto that has the whine sound.
occasionally the ford diffs will develop a hum from worn bearings but not usually a whine
Old 28-06-2012, 03:40 PM   #7
vesssh
I am getting my transmission serviced next week, so hopefully that eleviates that problem.
The transmission changes are very smooth
Old 28-06-2012, 03:49 PM   #8
TheSly1
my AU S3 has 335km on it, the only time i notice\d diff whine is when coming off the freeway and off the throttle and no brakes and the engine is coming down, a oil change in the diff to the proper 90w/130-140w whatever the correct oil is has fixed the problem this has happend on multiple occasions (ive had the car since 180km) the wrecker is an idiot..
TheSly1 is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2012, 07:36 PM   #9
vesssh
The wrecker said that when the diff fails it will just lock up, I hope this isnt true as the only time I drive my ute is when I tow my race car . . .
Old 28-06-2012, 08:22 PM   #10
BHDOGS
Put a banana peel in it
Old 29-06-2012, 08:25 AM   #11
Sox
RIP...
Sox's Avatar
A very slight whine may be normal for it's ages.
Both have some truth to it.
That's the most unlikely.
Complete bollocks, the gears are identical.
That's true.
Only from a shonk.
Yes, they'll be ok.
Obviously the shorter the better.
Most cars are geared quite tall for economy and noise regs. Not good for hill starts when towing.
Depending on how much towing you do, 3.7 or even 3.9 gears might be more suitable.
I wouldn't worry too much about the whine though, they need to be making quite a racket before they're close to failure.
Changing the oil can't hurt though.
Oval Everywhere...
Old 29-06-2012, 09:14 AM   #12
Mr Hardware
I've seen dozens of cabs cover half a million kays each, never ever ever heard of this happening.
Old 29-06-2012, 02:58 PM   #13
Sox
RIP...
Sox's Avatar
Oval Everywhere...
Old 29-06-2012, 04:04 PM   #14
bartsau
bartsau's Avatar
Having busted a non LSD 3.23 diff and a 3.45 LSD diff I can tell you with certainty they will give plenty of warning they are on their way out. There will be a whine which will get more constant and louder and then the clunking as there is slop/play in the diff and at this point it will start off very slight until you feel it through your bones on each gear change/kickdown etc.
There was 1 stupid event which took years of life out of my first diff and the LSD...well it coped an absolute thrashing over 2 years plus some 35 1/4 mile passes with hard launches some on slicks.
Looked after and not thrashed I feel the standard diff should live for a long time without any issues.
When mine were on there way out I changed the oil regularly and I feel this certainly prolonged the life of them.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2012, 10:47 AM   #15
Mainlube
Mainlube's Avatar
Diff whine is a miss match between the crown wheel and pinion.
Unless extremely bad (mothers grabbing kids ears on the foot path) it shouldn't shorten the life of a diff, generally doesn't cause excessive wear, only to your ears)
Our Group 4 super oils don't have a history of reducing diff whine, they're too thin.
You need oils school straight SAE 140 E P gear oil to quieten a diff much at all, it's a suck and see thing.
Steve
MainLube - Extreme Lubricants For Overdriven Machinery
Mainlube 175 Synthetic Race Oil SAE 10w60 (engine)
Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w80 (gearbox)
Mainlube 154 Synthetic Solid Boundary E P Gear Oil SAE 75w140 (diff)
www.Mainlube.com.au
Mainlube is offline   Reply With Quote Multi-Quote with this Post
