Old 19-04-2012, 12:38 PM   #1
poppa smurf
poppa smurf's Avatar
Default what is the next problem in the IRS
as the question states, I still have "noise" as in clonking and banging coming from my drivers side rear end
the centre bush has been replaced so i assume it's not that, only done one trip of around 4,000 kilometres since
I've had it checked out but nothing can be found......I've had a look myself and can find nothing
I'm getting a "clunk" on takeoff, not all the time but when the car is on a rise or similar
everything, that I can see and fell, feels tight?????
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2012, 12:49 PM   #2
turbodewd
FG Falcon fan
turbodewd's Avatar
Default Re: what is the next problem in the IRS
diff bushes?
turbodewd is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2012, 12:58 PM   #3
poppa smurf
seems more to one side.....mainly drivers......I cant find it
the diff bushes would/should be central unless the sound is travelling
Old 19-04-2012, 02:38 PM   #4
Bushbasher
When in doubt, GAS IT!!
Bushbasher's Avatar
Have you checked the lower wishbone/control arm bushes with something to get some serious leverage on them like a tyre lever or something. you might have a soft bush that only gives when under extra load like taking off up hill. Also look at the shock bushes and sway bar bushes the same way. Get some leverage on them and see what moves first.
Bushbasher
MINE- AUII Forte
Old 19-04-2012, 02:49 PM   #5
poppa smurf
I've had a jimmy bar under there and all seemed okay....ford and the yard I bought it from reckoned they checked them as well
but I guess a soft bush may evade all cursory tests....i'll have another look at them when I get home
Old 19-04-2012, 03:21 PM   #6
tex
Broken
tex's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: With the exception of maybe HSE2, nobody writes a review like Texy.
Check the lash in the axel CV's
The Scud GT
11.4 @ 128, 1.88 60ft.
tex is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2012, 04:28 PM   #7
ebxr8240
Performance moderator
ebxr8240's Avatar
IRS sends a shiver up my spine..
Reminds me of tax dept.. Lol...
Daily driver GTE FG..
Old 19-04-2012, 04:53 PM   #8
poppa smurf
scares me more than the internal revenue.....I have an accountant for that....mechanics cant/wont find this problem
Old 19-04-2012, 04:53 PM   #9
Luke Plaizier
Lukeyson
Luke Plaizier's Avatar
I just had a problem with loud clunking from the left rear of our SX territory.
I had already recently replaced the main lower outer and single upper outer cross-axis ball joints on both sides which is usually another possible source of noise (had to for rego though, this was 12 months prior). And the centre diff bush looked fine. Even checked the blade front bushes (had to do them recently on my BA) but it was fine.
Just recently replaced the shocks as it was still bugging me, and it has pretty much disappeared. Looked like the top bush on the left had torn and was letting the bolt hit the other ring.
One other thing to check are the sway bar links. Our Territory front links hard worn and and caused a clunking noise in the front on corrugated roads. I could still have rear link issues as I have not replaced those yet.
Lukeyson
If the human brain was simple enough to understand, we'd be too simple to understand it.
Luke Plaizier is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2012, 05:01 PM   #10
poppa smurf
doing some deliveries this arvo and really listened.......there seems to be two distinct sounds one is like a bush has let go and the other is almost like the top rubber on a shocker has let go
almost like it has no distinct "weight" on it.....is this a common occurrence for the rubbers on the shocks to go
may need to find someone to take the whole assembly out and go through it on the ground but it wont be any dealers
Old 19-04-2012, 07:05 PM   #11
GTP owner
GTP owner's Avatar
I have been chasing knocks and clunks from my BF since 10,000km. Everything has been checked over multiple times and i still have them. I really peeves me off, and is one of the reasons why i probably wont buy another new falcon.
Check - jack in boot.
-spare wheel secure.
-shock absorber mounts.
-shocks themselves.
-diff bushes - all of them.
-trans mount bush
-tailshaft centre bearing
-cv on axles
-driveline bearings
-diff freeplay.
-diff cradle mounting bolts
-exhaust mounts
-fuel tank mounts
-all bushes in the rear end, including sway bars
When you are finished with all of them and still have a bloody clunk - learn to live with it until you sell it.
XA coupe 8.8sec @ 150mph http://www.fordforums.com.au/showthr...coupe+drag+car
BA GT-P for the shed
Mustang GT for the other half
E3 chubsport - fully fat (and slow), sitting there waiting for me to get sick of it and sell it.
BA XR6T for a daily
NT Pajero for the bush
XB 4 door project- swallows a BF xr6 turbo
My dad is a generous bloke. He gave away his dead car batteries free of charge....
GTP owner is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2012, 07:14 PM   #12
poppa smurf
I've been in contact with a semi retired mechanic....i reckon we will be stripping her rear end down shortly and rebuild from the ground up.....just the matter of time
he charges $60 per hour instead of the $120 plus
I've looked into the jack and the spare and most of the obvious ones
but if I cant stop the clunks and bangs it will be shortly up for sale......I wont be living with it.....we travel a lot and we are used to near silence
Old 19-04-2012, 07:22 PM   #13
XR_6falcon
Have you had the rose (pivot point) bushes checked? There are a total of 4 each side inners, outers, lower and uppers. I have seen these regularly cause knocks in the rear end at work (I work for a ford dealer). Should not cause your clonck/bang on take off i would have thought, but anythings possible.
Big dreams, not enough money
Smoke tyres, not drugs
XR_6falcon is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2012, 07:31 PM   #14
poppa smurf
supposedly all have been checked but i didn't get a detailed report back from the dealership.....
the mechanic that I just spoke to smiled and said that the IRS has a lot of problems but all can be solved
this is the kind of feller I wish to deal with .....it's to the stage I will willingly pay out of my own pocket to get it repaired and have a quiet vehicle to drive instead of the embarrassment that it is now
I like the vehicle and look forward to driving it but the constant clunk's and rattles just make it very unpleasant
I've repaired/altered the brakes and have stopped that rattle (thanks to the folks in here) but the rear end is just so bloody frustrating
I've looked over everything that I can poke and pull but cant find it......disassembly is my next step
if the dealership had done it properly in the first place I think this would be quite a good vehicle
I think it can be again but it will take surgery
Old 19-04-2012, 08:33 PM   #15
GCRXR6
GCRXR6's Avatar
Ahh ... noises... don't ya just love'm. Had a similar noise in my BA XR6. Turned out to be a faulty shock. Had an EF that started knocking near the driver side foot area. .... was an ill fitted front bush in the right rear lower control arm.
The most annoying noise that I ever had was a knock sounding like it was in the front bush of the right rear spring of my XA. Had the noise from new. Only there sometimes on rough roads or heavy acceleration or brakeing.
Found it when I stripped her down to apply fish oil after a bath in a creek crossing. A flamin' small screwdriver in the rear door. Friday arvo in the factory?
Ya don't slow down as you get older ... you just enjoy taking longer to do it ... better!
GCRXR6 is offline   Reply With Quote Multi-Quote with this Post
Old 19-04-2012, 09:55 PM   #16
metalmania
metalmania's Avatar
Crank the stereo up.
metalmania is offline   Reply With Quote Multi-Quote with this Post
Old 20-04-2012, 12:15 PM   #17
mik
mik's Avatar
sounds like the problem you guys have is not the rear end but the guys diagnosing it.
Old 20-04-2012, 12:26 PM   #18
poppa smurf
YAY!!!.....found one.....the one that sounded "loose" or not supporting any weight .....drivers side rear shocker
replaced that, the other noise is still there
anyone is more than welcome to come and have a look and listen.....perhaps you can see and hear what a dozen experts in the field could not......diagnosis of IRS parts is not my field
and I will be the first to admit it
I've had it in 3 large full-time workshops now and one smaller private
Ford's
Holden's
private
the only one that could hear the noise is a half deaf older feller who is semi retired......he's getting the job of pulling the rear end out......problem is he only works 3 days a week.....and he's flat out!.....and I reckon I'll have to help him.....making a time is difficult
I honestly think the others could hear the noises but don't want the job
Old 20-04-2012, 03:13 PM   #19
GTP owner
GTP owner's Avatar
Congrates on finding your clunk! We drove my BF around without the rear shocks in...and it still clunked!
BA XR6T for a daily
Old 20-04-2012, 03:21 PM   #20
poppa smurf
thats how I found the noise in the shock.....drove around with it out.....I've still got one more to find and a noise from the front that I have yet to get to
just to find that one is a big step to making driving more pleasurable......I wont know it if I find them all!
