06-04-2012, 01:56 PM | #1 | ||
previously SMIKXR6
Hi guys i have a 2002 au falcon and i want to know how to remove the dash spear above the pasangers airbag cheers travis.
06-04-2012, 03:37 PM | #2 | ||
previously SMIKXR6
Anyone i need help asap cheers.
06-04-2012, 06:16 PM | #3 | ||
Found this for you.
Hope it helps. 1. Remove the airbag panel (will break the clips behind) 2. Undo the 4 10mm bolts to remove airbag 3. Remove the passenger dash vent 4. Feel behind the spear to locate and undo the 5x 10mm nuts Dash spear removed The plastic clips you have to break to get the airbag panel out are available from Ford for around $20.00 I think.
We salute those brave souls that enter the DARK side |
06-04-2012, 06:31 PM | #4 | ||
previously SMIKXR6
Thanks heaps mate i couldent find any info lol...
06-04-2012, 11:15 PM | #5 | ||
there should also be one screw on the right behind the climate control if you have a fairmont version that is
08-04-2012, 12:05 PM | #6 | ||
5.6L x 2 pilot
PM FAT245. I believe he has done this to his Lane.
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
08-04-2012, 12:58 PM | #7 | ||
previously SMIKXR6
Thanks guys but its a falcon no digital climate contol its anilog.
