moonlight rider
Both park lights are not working,low beam and high beam are working fine so am just wanting to know if anyone can tell me do the park lights run off the inside light(high beam,closest to the grill) or the outside light which is low beam and do they run off a bulb of their own,we checked the fuse under the dash and that is fine,any help is appreciated.
I build your wish list...
Is it a original ED XR 6 ?
If it weren’t for physics and the law enforcement, I’d be unstoppable.
#3 | |||
moonlight rider
Park light is in the front indicator.
#5 | |||
moonlight rider
moonlight rider
Sure enough someone has changed the xr6 indicators to the plain(made for just the indicator bulb)orange indicators.After doing some research it appears there is an extra light fitting on the xr6/xr8 indicators for the park light set up,and over here in kiwi land they are hard to come by.
#7 | |||
Parts bin special
Weekender 1964 US Falcon Futura convertible - Rangoon Red 260 Windsor V8, 4 speed manual, LHD, Electronic ignition, Mustang wheels https://fordforums.com.au/showthread.php?t=11470868 Daily 2014 SZII Territory diesel - basic runabout Previous Cars 1990 EAII Fairmont Ghia - Tickford engine, 5 speed, SVO wheels, bodykit, much more 2000 AUII Fairmont - XR wheels, Ghia interior 2010 FG XR50T ute - XR8 bonnet, Streetfighter intake |
Get the after market clean blinker ... Should cost around the 25$ per side ...
Then up the top you will see a casting mark in the plastic ... All you do is drill it out and put the park globe into it ... Very easy ..
