04-02-2012, 12:14 PM | #1 | ||
Thailand Specials
Hey guys, I need a new cat back exhaust for my Falcon as one of the mufflers is rooted, I thought I might as well as do the whole hog including a high flow cat, but would it pass a victorian road worthy with extractors?
Thanks much. |
04-02-2012, 01:58 PM | #2 | ||
Noise, emmisions and ADR.
good luck.... |
04-02-2012, 02:37 PM | #3 | ||
Thailand Specials
They don't check emissions on vic RWC I think
04-02-2012, 02:49 PM | #4 | ||
Call the mechanic who you are getting the RWC through and speak to them.
04-02-2012, 03:12 PM | #5 | ||
but the car has to appear to meet the emission levels set for the car
04-02-2012, 03:18 PM | #6 | ||
335 - STILL THE BOSS ...
Who is doing the job? You or a workshop? If its a workshop and you have asked for a RWC system, that's what you should get.
'73 Landau - 10.82 @ 131mph '11 FG GT335 - 12.43 @ 116mph '95 XG ute - 3 minutes, 21.14 @ 64mph 101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong! Clevo Mafia [SIGPIC][/SIGPIC] |
04-02-2012, 04:02 PM | #7 | ||
Thailand Specials
I was going to get a system off the shelf and do the work myself, but I'm not sure if I can get anything legal?
04-02-2012, 10:14 PM | #8 | ||
Peter Car
I wouldn't think it would make any difference to the cars roadworthyness. It doesn't have anything to do with noise requirements or emissions, just that its safe.
I've never heard of a car being knocked back for a RWC because of extractors or an exhaust, unless the exhaust is damaged or leaking etc. |
04-02-2012, 11:18 PM | #9 | |||
05-02-2012, 12:16 AM | #10 | ||
Peter Car
Nope. Again, not a safety issue, they are not the EPA.
05-02-2012, 12:47 PM | #11 | ||
Vehicles manufactured to comply with emission control ADRs must have all pipes, hoses, valves, sensors, fuel and air control devices and any other emission control equipment originally fitted by the vehicle manufacturer properly located and connected and not apparently damaged, deteriorated or altered in any way so as to appear ineffective.
Also check http://www.vicroads.vic.gov.au/NR/rdonlyres/9B3A858D-15A0-4572-90BF-3D08214BF7BE/0/VSInumber8Guidetomodificationsformotorvehicles.pdf
05-02-2012, 12:58 PM | #12 | |||
Oooh baby living in Miami....
05-02-2012, 01:01 PM | #13 | ||
I was told in very clear language that a 100 cpi "high flow" cat was illegal.
200 cpi was the bare minimum and 300 cpi was a safe bet. |
05-02-2012, 01:48 PM | #14 | ||
i not sure on the legalities these days , but in my eyes as long the extractors have heat shielding if/where they need it and have the oxygen sensor fitted that works correctly, those would be the things i`d be worrying about, and excessive noise of course, the other thing is........some insurance companies WILL NOT COVER YOU WITH EXTRACTORS, definately worth checking up on that.
05-02-2012, 03:01 PM | #15 | ||
V8 wannaabeee
"rwc place suspects a loud exhaust hes just going to tell you to make it quieter before he gives you the rwc cert" - that is what i was told by a a friend who does roady's
- they don't need to check emissions, if it sounds too loud, than it probably is too loud as long as your car is roadworthy, that includes the exhaust, it may not come down to a safety issue, but "is it roadworthyness" - you can't expect them to pass a car that is loud, they could lose their license Last edited by kyro_02; 05-02-2012 at 03:16 PM. |
05-02-2012, 04:17 PM | #16 | |||
Thailand Specials
There is an issue with one or two of the mufflers being rusted in the system and its causing a vibration through the exhaust when you drop from 2000 RPM down to idle. I thought I might as well as do the extractors and cat at the same time, but I'll just do cat back for now to get the roady. I don't actually want the car to be loud, so if I could replace everything and get the same noise as standard or even less, I'd be happy. |
05-02-2012, 07:32 PM | #17 | ||
It will be roadworthy as long as you make sure the postioning of the cat does not change at all, you keep your original cat and that all anti pollution gear stays on the vehicle and is connect as per original like oxygen sensors, egr if it has it
05-02-2012, 08:26 PM | #18 | ||
Peter Car
Just having extractors will not affect a RWC. As long as the cats are are in place and you have no exhaust leaks all is good.
They would obviously pick up those rusted mufflers as they would leak exhaust gas. |
05-02-2012, 09:04 PM | #19 | |||
Seriously though, people of my age went through this many many years ago...it did indeed used to be illegal to fit extractors, if they weren't factory on that car. They changed the laws because of the huge aftermarket industry and because they could prove fuel economy increases as a carbed engine breathed better and that they weren't just there for "hoon value"...people of all ages were starting to fit them as a normal mod when the time came for the whole exhaust system to be changed. I don't think it would be the extractors that would give you a problem...it would be whatever you did past that point... |
05-02-2012, 10:03 PM | #20 | |||
Peter Car
I know you hate modded cars so thats fine, but don't let your predudices blind you. Mechanics who do RWC's are not the EPA. Still yet to hear a single person reply they had, or new someone who was knocked back on a RWC because of either extractors or too noisey. |
05-02-2012, 10:06 PM | #21 | ||
Thailand Specials
I assume there would be an off the shelf option for something that is well within the legal limit anyways?
I don't want to have some fart cannon that wakes up the dead as I drive past. I'll ring up the workshop I plan to get to do the RWC tomorrow and ask for their clarification on the issue, as it is now it certainly wont pass anyway. |
05-02-2012, 10:11 PM | #22 | ||
....... sorry but cant help myself but have to agree with 2011G6E There are many on these pages that have problems with RWC's only because of noise ... not just because some gas is leaking, cat backs, extractors etc. Some are going through the dramas right this second.
And yes ..... mechanics can and very much do pick up a too loud an exhaust as part of the roady. They may not have the testing equip but believe me ...... they can knock it back just because. Recently I have had the Landau looked at to get a RWC .... the very very first thing that was pointed out by two different blokes was .... "Its too loud for starters ....... "
06-02-2012, 09:28 AM | #23 | |||
when you put the new system on, they stick a machine on it to check the pollutants, mix, etc?
My ride: 2007 Falcon Ute BF XR8 Orange, MTO. |
06-02-2012, 10:27 AM | #24 | |||
Also I know when I got my bike rwc'd I had to stuff steel wool in the muffler to shut it up, bike's have to be under 93db at 8000rpm.
2006 EGO BF mkII XR6 6sp Manual Lowered Prem Sound
06-02-2012, 06:54 PM | #25 | ||
Fixing Ford's **** ups
The V8 NF Fairlane I have has factory style extractors. 4 individual pipes per side, going into one outlet point, per side, just before the cats.
Do you need pics from underneath the car where they join into the system? Happy to oblige. So are extractors illegal. Doubt it when the factory fitted them in 1995. (Perhaps before) The only issue would be noise. Your call from that
A wheel alignment fixes everything, when it comes to front end issues. This includes any little noises. Please read the manual carefully, as the these manufacturers spent millions of dollars making sure it is perfect.....Now why are there so many problems with my car, when I follow the instructions to the letter?....Answer, majority rules round here Lock me up and throw away the key because I'm a hoon....I got caught doing 59 in a 60 zone Last edited by svo supporter; 06-02-2012 at 07:15 PM. |
06-02-2012, 09:10 PM | #26 | |||
Peter Car
Its the EPA's job to test how much noise a car is making, not a mechanic doing a RWC. If I had a mech telling me its too noisey i'd argue the point that he's not the EPA. Just having a noisey exhaust doesn't make a car unsafe. Thats the police and EPA's job to enforce. Although maybe it does happen as some have said, but I disagree with it. |
06-02-2012, 09:16 PM | #27 | ||
You can disagree but what the rwc tester says will have more load than what you think.
07-02-2012, 10:16 AM | #28 | ||||
07-02-2012, 01:12 PM | #29 | ||
Sorry, just noticed you're in Geelong...here in Queensland you do indeed get pinged for a car being too loud at a roadworthy. They might "not be the EPA", but they also know that if they pass a car for roadworthy, and it soon after gets done for excess noise (or anything else illegal or dodgy), the Transport Department will come looking for whoever gave the roadworthy with a pineapple and a tube of Deep Heat for a lubricant...
And it isn't the extractors that make a car "loud"...it's what's been done to the exhaust after that point that makes it loud. There are plenty of ways to make an exhaust have a nice note and still be well within the noise limits and still flow well. I've seen a 700hp R32 Skyline that was actually under the decibel limit because of a carefully designed exhaust system...a true sleeper. Arguing with a roadworthy mechanic that he doesn't know what he's talking about and that whatever you're arguing the point on is, in your unexpert opinion, "safe" doesn't get you anywhere... |
07-02-2012, 01:33 PM | #30 | ||
[quote=2011G6E]Sorry, just noticed you're in Geelong...here in Queensland you do indeed get pinged for a car being too loud at a roadworthy. They might "not be the EPA", but they also know that if they pass a car for roadworthy, and it soon after gets done for excess noise (or anything else illegal or dodgy), the Transport Department will come looking for whoever gave the roadworthy with a pineapple and a tube of Deep Heat for a lubricant...
quote] hahaha
