Old 14-12-2011, 10:24 AM   #1
sooty43
Default metal in oil
At the last two oil changes I have noticed some very fine flecks of brass inthe oil. The car has an oil change every 3 months and is AU1 on gas. Has any one got an idea what brass bits insiide the motor are wearing out? btw the car has done 300,000 kays.
sooty43 is offline   Reply With Quote Multi-Quote with this Post
Old 14-12-2011, 01:28 PM   #2
b2tf
not here much anymore
b2tf's Avatar
Default Re: metal in oil
6 or 8?
RAM 1500
Old 14-12-2011, 06:56 PM   #3
sooty43
Sorry mate, its a six.
Old 15-12-2011, 01:11 AM   #4
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Brass? You'll be pushing **** uphill to find brass inside one of those engines....
Definitely not magnetic? Have a listen with a screwdriver or extension bar as a stethoscope, see if you can find a noisy spot. Most likelly it's off the cam beds, but another possibility is what used to be the dizzy cam. The bearings on those sometimes give up then the chain pulls the cam through the block :( That's easy to check - remove the cam timing sensor (with engine at TDC) and hand crank the engine while measuring cam runout.
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 15-12-2011, 04:07 AM   #5
Day-mow
rexnet
Day-mow's Avatar
Oh dear.
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 15-12-2011, 11:23 AM   #6
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
erm, what's an oil pump in an AU made out of?
Old 16-12-2011, 01:52 AM   #7
mongrelEF
Bugger!
mongrelEF's Avatar
Case-hardened steel, mostly.
