10-12-2011, 01:21 PM | #1 | ||
Next upgraded Mk1 Leopard
Hi all
I have reset my tensioner again (five times now) and the car still sounds to noisy. I have a video in my workshop build area. Any thoughts or comments of what I am doing wrong would be appreciated. Follow this link to the workshop build. http://www.fordforums.com.au/showthr...35#post4024735 UK
10-12-2011, 06:39 PM | #2 | ||
have you had a good look down inside the timing cover for broken chain guide/s?
10-12-2011, 06:49 PM | #3 | ||
Smile
Uncle Ken mate hi. Remove the rocker cover and check that the tensioner has the chain nice and tight not floppy.If its not tight then get another tensioner or maybe youve cracked a guide?
Stingray Car Security ph 0414445444 Single din radio fascias for fg to fgx fords Australia wide . FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/ Site Sponsor See Sponsor Stingray Car Security 😍👌✌ AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again |
10-12-2011, 07:15 PM | #4 | |||
Uk
10-12-2011, 09:14 PM | #5 | ||
hmm spacer?....2 prongs on the end of the tensioner assembly slot against the chain guide
so you havnt inspected for broken chain guides? Last edited by AU Mont; 10-12-2011 at 09:20 PM. |
10-12-2011, 10:57 PM | #6 | |||
The part on the right? This is intact. UK
16-12-2011, 10:13 PM | #7 | ||
how did you go Uncle Ken?
17-12-2011, 04:05 PM | #8 | |||
UK
22-12-2011, 08:50 PM | #9 | ||
I ♥ EDM
Would this problem cause a knocking noise under low rpm acceleration? (including backing off the throttle at low rpm)
22-12-2011, 09:24 PM | #10 | ||
Got the car back yesterday
So to recap...having reset the tenisoner many times it turns out the noise was not the tenisoner but a broken lifter !!! Joe at Cresent motors at Liverpool replaced all the lifters and checked the throttle change I had done. So now I have to flush the oil a few times before the new lifters before quiten down. The car felt good coming back from Liverpool to Castlehill. Flushed and Changed the oil/filter today..will postan sound grab on the weekend UK
23-12-2011, 01:37 AM | #11 | ||
good your baby`s on the road again, i don`t think i have heard any mention of a broken lifter on an Au before, ah well long as she`s a goer again.
23-12-2011, 09:23 AM | #12 | ||
Yeah I had firsts
UK
23-12-2011, 05:54 PM | #13 | ||
Its sounding better already..see the two sounds bits in my build section
http://www.fordforums.com.au/showthr...92#post4044292 UK
