Old 19-11-2011, 05:46 PM   #1
jerryaus
Default do u understand ur feista car computer?
Hi guys, I think not many people know that how to put the car computer into manufactory mode, here is the way~~~
First, push and hold the tripmeter reset button, then turn the ignition to II position, release the reset button until u see the information display shows "test".
To logout the manufactory mode, just simply switch off the ignition.
On the information display, u will see some different numbers, some of then might be different as what I wrote here, but just follow the step, here we go:
1.9A9E: checking all meters.
2. checking the lcd screen
3. checking all LEDs
4. showing computer ROM level & model
5. Er.....: no require
6. E...: no require
7. dt.....: the manufacturing date of meters
8. DTC codes
9. NONE
10. SP...mph: car speed
11. SP...km/H: car speed
12. SG....: no require
13. tA....: engine speed (RPM)
14. tg.....: no require
15. od....: mileage
16. F .....: fuel system, 000-009>>short circuit, 010-254>>normal, 255>>out of order
17.fg....: no require
18. FL....: no require
19. FP...: fuel position, from 00 to 64, 64 means 100% full tank, FF means unable to read
20. XXX C: engine coolant temperature, 0-254, 255 means unable to read
21. ...Cg: no require
22. bt...: car battery voltage
23. dtE...: remain KMs until fuel running out
24. rAF...L/100KM: average fuel consumption since you change or remove the car battery last time, or from new car
jerryaus is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2011, 08:54 PM   #2
Caydus
Caydus's Avatar
Default Re: do u understand ur feista car computer?
Yea, i think there's a thread a while ago dealing with the trip computer's factory diagnostic mode which gives all this info.
It's nice to have all this, especially since the needle speedo is usually calibrated to read higher than actual speed and apparently the factory diagnostic mode gives the true speed and for the engine temp, which doesn't have a guage on the dash for.
Just need to find a way for it to display without having to start the compy in diagnostic mode.
Caydus is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2011, 12:11 AM   #3
vhcbm
having Fiesta withdrawals
vhcbm's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Ford couldn't fix my BlueTooth issue. This member posted a download link, with instruction, on how to do it myself. One week on, the unit hasn't played up once. Three different dealers told me to virtually 'Live with it.
There's a heap of videos on Youtube about it as well.
New: Ford Focus RS in Ultimate Green number 82/315
Past: 2009 Ford Fiesta LX in Vision Blue - Sold
vhcbm is offline   Reply With Quote Multi-Quote with this Post
Old 20-11-2011, 04:01 PM   #4
GoesLikeAZetec
GoesLikeAZetec's Avatar
yep there are already threads on this
GoesLikeAZetec is offline   Reply With Quote Multi-Quote with this Post
