Old 16-08-2011, 10:38 AM   #1
GCPursuitPower
AUII XR8
GCPursuitPower's Avatar
Default A/C Removal
Hi all,
I am just wondering if it is at all possible to fully remove all A/C components in an AU V8 and have it still have the cooling system run correctly, I want to remove the A/C to lighten the load for track racing. How would I go about such a thing?
Any help is greatly appreciated.
Brett
Ford XR8 AUII Sedan, 5.6L Stroker Engine 250kw.
GCPursuitPower is offline   Reply With Quote Multi-Quote with this Post
Old 16-08-2011, 06:31 PM   #2
FGII-XR6
FGII-XR6's Avatar
Default Re: A/C Removal
you could do it but you would have to either leave the compressor in or rig up an idler pully to take it's place
[SIGPIC][/SIGPIC]
Rides:
Old 17-08-2011, 05:54 PM   #3
GCPursuitPower
AUII XR8
I'd be happy to leave in the idler pulley system, I just want to get rid of the A/C unit and compressor lines to free up room in the engine bay and weight inside the car.
I was wondering on how to go about it as there are lines everywhere and some of them have coolant from the engine in them, so if I remove the system which lines have to go where so the coolant system still does it's job like normal.
Old 17-08-2011, 06:20 PM   #4
FGII-XR6
FGII-XR6's Avatar
the ones with coolant are heater hoses and there will be 2 of them coming from the engine just run a short hose between the 2 points on the engine where the are now. in one of the heater hoses there will be a vacum operated tap just block the vacum line
[SIGPIC][/SIGPIC]
Rides:
Old 18-08-2011, 10:05 AM   #5
GCPursuitPower
AUII XR8
Thanks for the info, I will give it a try.
