09-06-2011, 02:27 PM | #1 | ||
Dear members,
I have a difficult time choosing the appropriate solution. The manual indicates an anti-freeze ethylene glycol antifreeze solution [ESR-FM7C-35C or ESB-M97B-18C] based on old AS standards(?). Presently there are for sale solutions, like ESE (second E, rather that R) M97B18-C Type A on AS2108-2004 standards, but there are others for Type B. I'm also confused if I should find just an a/freeze - a/boil, rather that a (just) a/freeze solution. Finally, should I just stick on the abovementioned chemical compound only? I'm worried that if something else is used, it may affect the engine. Can you please assist? Many many thanks, Flokos. |
02-07-2011, 06:43 AM | #2 | ||
Hi Flokos, use Nulon anti freeze, anti corrosion @ 50/50 with de-mineralised water. Reasonably priced, 4 year life and good reputation. I have no idea why nobody has offered advice on this. Recommend flushing your cooling system before you put the Nulon in. Gives the Nulon a fresh start with no residue of anything else to cause problems. By the way, Nulon gives a good warranty/guarantee and the product is recommended for virtually all motor vehicles as it meets or exceeds most Australian and international standards.
07-07-2011, 07:15 PM | #3 | ||
Again Graham7773, your info is invaluable. Well, the car's manual/specs are a bit outdated and there is some risk in using the wrong product, I suppose, as you can see from my confusion. Cheers and Cheers from my 242k tank!
