Old 30-05-2011, 03:58 PM   #1
V8XTasy
Default ECU removal - how?
hi,
I want to get to one of the wires to the ECU on my 5.4 V8 3v Falcon BA, but the connectors are under the ECU and the ECU appears to be riveted to it's bracket which is riveted to the body. Why? Anyway, what's the best way to get the ECU off its bracket?
Thanks
V8XTasy is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2011, 04:06 PM   #2
yift
Technical Contributor: For members who share their technical expertise. - Issue reason: Countless sensible, accurate mechanical advice on all things Falcon and Territory.
Default Re: ECU removal - how?
you dont need to remove the ecu just to remove the wiring loom. you can easily unclip the loom from the ecu and drag it out from under there.
if you still want to remove the ecu grab a hack saw and cut a line into the rivets (sheer bolts) and unscrew them. when your done get the sheer bolts from ford and tighten them up until the heads snap off.
yift is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2011, 04:53 PM   #3
V8XTasy
Thanks, I'll give it a try tonight.
Old 30-05-2011, 05:10 PM   #4
fat4D
easier way to remove rivets is to get a drill bit just bigger that the center hole and drill slowly until the the top starts to spin. once this starts to happen grab a hole punch and give it a smack and the rivet will pop out.
trying to srew it wont work
Now Ford-less
But good things are coming in 6 months
fat4D is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2011, 05:17 PM   #5
FGII-XR6
FGII-XR6's Avatar
as stated above they aren't actually rivets they are sheer bolts your method risks stripping the thread
[SIGPIC][/SIGPIC]
Rides:
Old 30-05-2011, 06:52 PM   #6
yift
speaking from experience, go do what you suggest and let me know how you go.
Old 31-05-2011, 09:10 AM   #7
V8XTasy
thanks for your replies. I tried the slot method, but the bolt was in too tight to unscrew. However, I managed to remove the connector from under the ECU anyway.
