more of an alternator
hi all i have a ford au fairmont on gas it wont start after stopping at shops
meh.
![]() Join Date: Jul 2010
Is it out of gear?
If it is out of gear, Try moving the shifter from P to N, then see if it will crank.. Just run it quickly from P to 1 then back again.. then try starting it in P and N If that works, then it's your inhibitor switch.. Cheap and easy part to replace..
tried it it n and p no difference still turns over
is it an egas, or has it had an aftermarket gas conversion?
its aftermarket
dont all the dash lights usually go off when turning over
any other symptoms , has it been running well prior to this?
car has been fine wife said she jumped in tried to start it went to fire then stopped now just cranks over
Since the conversion, is it now only able to run on gas...
If so, does it automatically switch to petrol for starting... If you can switch to petrol, do so and try that... Cheers... ![]() |
got fuel in it? not uncommon for people to overlook stuff, i had a lady once ask for help with a flat battery, after dragging a booster battery and jumper leads 200 metres to her car, the woman had forgotten to put the tbar into park
not here much anymore
Has the interior light fuse blown?
RAM 1500
