21-04-2011, 05:54 PM | #1 | ||
5.6L x 2 pilot
Hi all. The time has come to give the LTD a brake upgrade. I have been trying to research options on the net, but I am sure that just makes life more confusing. So far, I have looked at the PBR option and got a quote from Race Brakes in Sydney, only to find these are supposedly just slotted B series brakes. I think the term used was "taxi spec". Brembos are an obvious choice, but I am sure they are one of the most expensive choices as well!
Rather than beating around the web, I figured it was smartest to ask those in the know - you guys. Factors that I need to consider are obviously inital cost and more importantly maintenance costs - ie replacement pads and rotor wear/replacement. Any feedback advice greatly appreciated guys.
2002 AU II LTD 5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust. Quarter Mile: 13.73 @ 105.86mph Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024 2002 XR8 pursuit 250 Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
21-04-2011, 06:27 PM | #2 | |||
AU DIE HARD
It really depends on what your needs are if your going to the track, or just a bit of spirited driving. Cheapest option would be the slotted rotor with a decent pad option, Being a S2 the standard set up isn't that bad with that option , next would be the premo upgrade ( PBR C4 kit i think it is ) the twin piston in the caliper is smaller but the rotor steps up a fair bit, this with slotted and drilled rotors with good pads are very effective, and provided you can get a set with the mounting hardware are reasonable priced second hand , If you want the whole box and dice and have the cash go with Brembo or Alcon race type set up. Give FTG a call they often have some good second hand options
21-04-2011, 07:44 PM | #3 | |||
5.6L x 2 pilot
This is what I was looking at PBR PK2 - was not priced way out of my league. http://www.pbrperformance.com.au/doc...AUIIFalcon.pdf Not sure what Brembo or Alcon are worth, but I thought this was reasonable. Your thoughts?
21-04-2011, 07:55 PM | #4 | ||
Just slidin'
Go to BA fronts and rears. Fronts you just need the calipers, rotors and pads, get a good set, and rears you just need rotors and a good set of pads. It is all bolt on, and shouldnt take more than an hour.
The next step up wuld be to a BF (?) 320 odd mm fronts, and bigger rears. Not sure how it all bolts on though.
MD Mondeo - For the family
21-04-2011, 08:41 PM | #5 | ||
rexnet
really. BA fronts just bolt on? hmmmmmmm
but QFM pads and RDA/DBA slottered rotors. but its the pads that will make the difference. i do some pretty spirited driving in my XR and i have QFM K500's and im really really happy with them. rotors havn't really warped and brake fade is pretty minimum. i've herd the HPX is a better pad. so seeing as you want something serious go that. i just found the K500's on Ebay and hit that up. talk to site sponsor race brakes syd. very helpful |
21-04-2011, 09:29 PM | #6 | |||
AU DIE HARD
21-04-2011, 10:50 PM | #7 | |||
For improved braking, it's no so much size that makes the difference, but the disc swept area and pad surface area. IMO, BA brakes on an AU is a sensible upgrade, and with slotted rortors getting rid of built up gasses, and a decent set of pads (such as the QFMs recommended), your stopping power should be more than you'll ever need. auIILTD - Your other option, if you realy want bigger, is to swap my Tickford setup with RDA slotteds onto your car (and your stock AU2s onto mine), with cash difference my way (you do the research, and come up with a fair price). Straight bolt on, and you get the 320odd mm rotor, twin piston callipers with Tickford wings, and they've just had a calliper kit through them so are as good as new. Replacement discs are around $300 odd for RDAs, $450 odd for DBAs, and pads are around $75 for the front set. I have a set of rear Tickford grooved discs that just replace your stock ones - yours for nix if you take the fronts as well.
22-04-2011, 08:28 AM | #8 | ||
5.6L x 2 pilot
Thanks JC - food for thought. Definately worth considering. The PBR kit linked above goes from 287mm to 325mm on the front and to 303mm on the rear. Pad area goes from 62cm sq to 73 cm sq - and they are new. I will think about it a bit more.
24-04-2011, 10:11 PM | #9 | ||
Stay Classy ™
Although a little exxy, Brembos are the business. They've come down in price in the last year or two, I cry when you can get a full set of 4/4 new for under $4k complete, I paid $4.8k. I reckon you'd be able to pick up a cheap second hand set for around 2.5k to 3k without too much trouble, plus you have the rims already to fit them.
25-04-2011, 09:16 AM | #10 | |||
5.6L x 2 pilot
Cheers and thanks.
25-04-2011, 09:21 AM | #11 | ||
Stay Classy ™
Haven't had to replace street pads yet and I've had them in since end of 2008, I've probably done 30-35k on them and I reckon they've got another 5k in them.
Only pads I've bought is dual carbon pads from Matt for around $450 but they are a track only pad, of which they're barely showing signs of wear after 3 track days. I'd speak to Matt to get a price on regular Brembo pads, but from what I've heard the genuine ones are a bit expensive ... there are a lot of other options out there that would be cheaper and perform the same. |
